VSC - Check Engine: Excessive gas in Oil???
Super Moderator
Perhaps that explains why it appears to affect more IS250s (which are direct injection only) than IS350s (which use both port injection and direct injection). FWIW, I do lots of short trips on my IS350, and haven't had this problem.
Originally Posted by dang_is250
Dealer said that because the car is a direct fuel injected vehicle, fuel builds up in the oil over time. Usually, the fuel will burn when the car is at a nice operating temperature. However, if you take a lot of short trips and don't let the car reach operating temp. before shutting off the engine, fuel will build up. When the car detects fuel in the oil, it throws the CEL light. This explanation made sense to me. For the last month I have been taking many short trips as I drive 5 mi. each way to the bus stop to get to work in 10 degree CO weather. Anyways, I was wondering if anybody else who has been having this problem has been taking short trips in their IS.
I too doubt there is a sensor that checks to see if there is too much fuel in the oil. Anyways, I thought I'd include the comments that were on the invoice. "Excessive fuel odor in oil 151011 T1=15 T2=99 50 replaced engine oil and filter advise customer to drive less short trips need to allow engine to get to full operating temp before shutting off." Hopefully, the code doesn't flash again. I agree, there needs to be a fix for this.
Originally Posted by Kamikaze2b
I also have less than a 5 minute commute, but I will say that it's a "spriited" drive, and my car gets to operating temp every time.
Originally Posted by ES3
Just to confirm has ANYONE had this problem with a 350? Also, can someone please link the original post here, just so we can all stay on top of it? Hope Lex finds a fix!
After owning 36 cars, I have never had to either avoid short trips, or purposely drive out of my way so as to go a longer distance. I have to think that there is a solution to this problem other than telling me to drive further. I did not have to worry about short trips in my Audi A4, Audi S4, or BMW . Surely I don't have to do it now.
Not incidentially, I have though since I bought my 250 AWD that the idle is higher when cold than it needs to be and the fast idle is maintained longer than it needs to be. I suspect that this is the problem and not my driving on short trips. I like being able to get to the Hospital in 5 minutes so I don't want to have to give it up. I'll change cars first!
There's obviously a software issue, though whether or not it's caused by an actually mechanical problem is going to have to left to Lexus to determine.
I'm going to try to pay attention to my idle in the cold as well vs. when the engine heats up, any idea how much higher your idle revs in the cold?
