After only a month and only 1000 miles, my check engine light and check VSC came on. I dropped my car off at the dealership and then a few hours later lexus called me and described the same exact problem that is mentioned here
It makes me kinda nervous that there was gas in the oil ( or could be ) and it seems like the problem could or will return... how would you guys handle the situation or what are your thoughts?
Wow thats a surprise coming from lexus, now only makes me wounder if it was worth the extra $$. I would def keep going back to the dealer to get it check out to see if it continues. Well good luck, hopefully its only a one time thing.
Couldn't gas in the oil cause permanent damage to the engine? Also, as if I wanted to bring my car into the shop all the time, I would've got a used dodge neon or something, not a lexus...
mike
Gas in the oil is bad for a variety of reasons, the main one being it dilutes your oil and basically decreases it's ability to lubricate the bearings and other surfaces that need a viscous surface between them.
Your car would have to be running ridiculously rich to end up with gas in your oil. That, or you've got an inginition problem. Cylinder misfiring, leaking injectors, something along those lines.
Gas has a pretty potent odor. Pull your dipstick and take a whiff....
Gas in engine oil CAN be bad, but old radial aircraft engines used oil dilution for years on shut down to allow them to start in cold weather. By the time they reached operating temperatures the gas would have evaporated. On todays modern closed engines it probably would cause more harm than good. Now, leaking injectors, yea, I'd put money on that for sure.
__________________
2006 Lexus IS350 Lux Package
2009 Toyota RAV4 Limited V6
2009 Toyota Sienna LE
1989 Celica All-Trac Turbo (JDM ST185)
1992 Celica FWD GTS w/MR2 Turbo motor
Just to throw in my own problem I had. I too once had the check engine light and VSC light come on in my wifes 04 RX330 last year. I called the dealer, made an appointment, but the earliest they could take me in was a week later. The next day all the lights went off. Finally when it reached the dealer they couldn't diagnose the problem because the check engine lights were off and no codes were stored. Nothing was done and I haven't seen the problem again since yet. Like some of the others, gas or gas cap probably wasn't the problem because it was at least 1/2 way though a tank. Anyway, the service manager said they did see this same problem come up before but didn't really know what it was.
Vehicle Skid Control (VSC) senses the onset of loss of lateral traction and helps the driver stay on track. Input from four wheel-speed sensors, a yaw-rate (directional) sensor, a deceleration sensor, and a steering-wheel-angle sensor is communicated to the VSC computer. The system has the ability to reduce power and to control the brake actuator. Working with both ABS and TRAC, the VSC system helps the driver to compensate for loss of lateral traction, which can cause skids and loss of vehicle control. Lexus Vehicle Skid Control (VSC) is an electronic system designed to help the driver maintain vehicle control under adverse conditions. It is not a substitute for safe driving practices. Factors including speed, road conditions and driver steering input can all affect whether VSC will be effective in preventing a loss of control.
Mike
Keep us informed on what happends. Hopefully its not anything major.
