Another interesting Service menu found! (adjust bluetooth sensitivity)
Old 08-10-06, 01:37 PM
MeTrO
MeTrO's Avatar
me too...it works
Old 08-10-06, 01:46 PM
pocky
mooncake master
pocky's Avatar
Cool, will play with it tonight!
Old 08-10-06, 01:55 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,849 Likes on 2,334 Posts
From the FSM...page NS-54
1. START DIAGNOSTIC MODE
(a) There are 2 methods to start diagnostic mode. Start
the mode by using one of them.
(b) Method 1
(1) Start the engine.
(2) While pressing and holding the "INFO" switch,
operate the light control switch: OFF → Turn ON
→ Turn OFF → Turn ON → Turn OFF → Turn
ON → Turn OFF.
(3) The diagnostic mode starts and the "System
Check Mode" screen will be displayed. Service
inspection starts automatically and the result will
be displayed.
(c) Method 2
(2) Switch to the "Display Check" screen.
(3) From the display quality adjustment screen,
touch the corners of the screen in the following
order: upper left → lower left → upper left →
lower left → upper left → lower left.
(4) The diagnostic mode starts and the "System
be displayed.
2. FINISH DIAGNOSTIC MODE
(a) There are 2 methods to end diagnostic mode. Use
one of them.
(1) Turn the engine switch off.
(2) Press and hold the "DISP" switch for 3 seconds.
Of course there is more info in the book, but these are the two ways to access the screen.
Old 08-10-06, 10:17 PM
stevejenn1
stevejenn1's Avatar
What settings and levels did you change?
Old 08-11-06, 05:52 AM
Mike_TX
Mike_TX's Avatar
When you enter this diagnostic screen, does it say "CHEK" beside Audio on yours?
Old 10-30-06, 09:01 AM
ES3
ES3's Avatar
Now if ONLY this would allow us to get into '07 nav override!
Old 04-09-09, 06:37 AM
Squrrell
Squrrell's Avatar
This is GREAT. I've had people complain lots as well. I've just used the menu to adjust the send a receive volumes slightly. There's also a "voice quality" setting that you can input a numerical value for. Mine is set to "00". I didn't want to change it, since it says see manual, and it will be very difficult to determine what the effect is.
Does anyone have a manual, or any idea what values to use?
Old 04-09-09, 07:07 AM
ES3
ES3's Avatar
Don't have my manual handy right now. Very curious to see if the "value" may make my I-phone 3G not break up with my car. It's never worked well!
Old 04-09-09, 10:59 AM
tex2670
tex2670's Avatar
nice bump!
Old 04-09-09, 01:09 PM
Squrrell
Squrrell's Avatar
Mine either ES3, nor the HTC phone I had before the iPhone. Only benefit was getting the battery life and signal strength indicators on the screen. Damn Apple for not providing an address book dump!
Old 04-10-09, 10:54 AM
j-spizzy
j-spizzy's Avatar
They are going to with the 3.0 software coming out in june.
Old 04-13-09, 06:17 PM
Squrrell
Squrrell's Avatar
Sweeeet!! That's one feature I had not read about. Thanks for the heads up!
Old 04-29-09, 12:01 PM
twixx007
twixx007's Avatar
Originally Posted by jlin101
now only if someone knows how to make the vent mode in IS350 (with smog sensor) stay in AUTO when the engine is turned off!
I found a fix for this. Get the new 8.1 Nav disk. The update will fix your issue as it has resolved mine. Good luck!
Old 04-29-09, 12:06 PM
rebs
rebs's Avatar
Really? the 8.1 nav disk fixes this issue? How? Is it like a general firmware upgrade or something?
Just curious cause it seems like Lexus should be providing those to us for free then if it resolves the issue ;-)
Old 02-08-10, 11:43 AM
celmei
celmei's Avatar
Hi Muzzman1,
Sorry to bother you again, I am not good at cars, I would like to adjust my blue tooth as well. Can you let me know where is the parking light switch? BTW, I haven't try it out yet, just would like to clarify it before starting.
"first hold the "info" button (I did it for about 5 secs) then switch your parking light switch from off-to parking lights-repeatedly while still holding the info button....it takes about 5-6 cycles...an poof the NAV screen enter yet another Service menu. From there I navigated to a bluetooth menu where I was able to adjust the Microphone volume higher so that people can hear me better!
Quick Reply: Another interesting Service menu found! (adjust bluetooth sensitivity)
