Old 01-07-15, 12:43 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
Wanna turn off VDIM? :)
Old 06-18-06, 12:12 PM
  #151
EBMCS03
EBMCS03's Avatar
Can I ask what that button is? when you push the brakes does that button get pushed? or is it the other way around?
So if I put somthiing in between the yellow and blue thing will it help activate my brakes faster?
I'm trying to see if thats the culpruit for my brake light problem!!!!!
https://www.clublexus.com/forums/sho...d.php?t=214831
Edit: actually reading post #30 I think its the other way around... when you push on the brakes it doesnt push on that yellow button anymore... meaning once that button is released the brake lights come on.
Am I right? Can you confirm this CaymanDive?
Old 06-18-06, 12:23 PM
  #152
caymandive
11 Second Club
caymandive's Avatar
Yes, when you push in the brakes it releases the button. When you release the brakes it pushes the button in.
Old 06-18-06, 02:08 PM
  #153
EBMCS03
EBMCS03's Avatar
Thanks for the confirmation. I'll check into it now that I know what that button does and see if it can be adjusted to make the brake lights light up earlier into the pedal travel.
Old 06-18-06, 03:07 PM
  #154
RCFormante
Supercharged!
RCFormante's Avatar
Heres how I do it and it works 100% of the time:
1. Start the car up and keep holding the foot brake.
2. While still holding the foot brake, press the e-brake until it lights up on the dash BRAKE. Let go until it does not show the BRAKE no more, do it twice and on the second time, hold it.
3. While still holding the e-brake, let go of the foot brake. Press the foot brake, let it go and then press it again and hold it.
4. Repeat Step 2.
5. Repeat Step 3 and the car with squiggly lines should light up. If not, repeat Steps 2 and 3.
Old 06-18-06, 03:17 PM
  #155
EBMCS03
EBMCS03's Avatar
Haha I think thats a funny symbol... its like Woooo you better watch you... you're going to lose control...
Old 06-18-06, 08:50 PM
  #156
Payam
Payam's Avatar
I can get it 100% of the time too as long as I wait for the system start-up check to finish.
Old 06-19-06, 12:23 AM
  #157
HaveBlue
HaveBlue's Avatar
That switch is what is called a double throw normally closed switch. In other words it makes connections when it's not pressed. It is adjustable for height. In fact if you cycle it too fast, the ECU won't register it as a pulse as I found out. There must be a slow debouncing circuit buffering the ECU.
Old 06-19-06, 07:35 AM
  #158
caymandive
11 Second Club
caymandive's Avatar
Yeah that makes sense. BTW...what do you do for a living? Are you a mechanical engineer?
Old 06-19-06, 08:36 AM
  #159
phatboyc
phatboyc's Avatar
...Repeat Step 3 and the car with squiggly lines should light up...
When I do the dance for “DYNO” mode I get the regular TRAC OFF light on my dash. The same one if I would of pushed the trac off button. I don’t see any squiggly lines mentioned by IS350S... Anyone else or am I doing something wrong.
Old 06-19-06, 08:45 AM
  #160
Payam
Payam's Avatar
It's the same light as if you pressed the TRAC off button.
Old 06-19-06, 08:50 AM
  #161
phatboyc
phatboyc's Avatar
Makes sence cause the burnout I did after was smoking. Seemed faster than 50km. Thanks.
Old 06-20-06, 09:42 AM
  #162
HaveBlue
HaveBlue's Avatar
I have a degree in Computer Science with a minor in aerospace engineering so my vast Electrical Engineering experience allows me to short things out at gigahertz speed. So it only guarantees that the circuit works on paper.
Old 09-27-06, 09:57 PM
  #163
mattssi
mattssi's Avatar
I can't fn get this damn thing to work! Tried 3 days in a row! frustrating.
Old 09-27-06, 10:17 PM
  #164
mattssi
mattssi's Avatar
Just got it!! YAY
Old 09-28-06, 10:13 AM
  #165
ES3
ES3's Avatar
It's funny how a slippery rear end, will bring about persistance!
Quick Reply: Wanna turn off VDIM? :)
