How does the car sense the passenger?
When my friend got in my car today, the buckle seat belt warning chime kept going. When he got out of the car, the chime didnt turn back on. How does the car detect the passenger? I assume there's some sort of weight sensor in the seat?
probably not. The reason for the weight sensor in the front passenger seat is so that the front airbag strength can be adjusted based on passenger size/weight. There's no such need in the backseat. It was the front airbags that caused fatalities in small passengers who sat too close to the dashboard a few years ago. The IS even has bi-lobed front passenger airbag to decrease direct impact with the face.
Originally Posted by enigma354
I wonder if it's bad to wear glasses during an airbag deployment.
Buzzer Reminder Cancel Mode Setting
1) Set the LCD on the combination meter to the ODO display.
2) Press and hold the TRIP meter reset **** for ten seconds or more within six seconds of turning the power source to IG-ON. Fastening the driver's seat belt or front passenger seat belt while holding the **** cancels the buzzer reminder.
4) Performing steps 1) and 2) again when the buzzer reminder is off exits cancel mode.
5) The cancel mode will also exit when the battery or combination meter connector is disconnected or reconnected.
Lex
The occupant detection sensor, which is enclosed in the seat cushion of the front passenger seat, is used to detect whether or not the front passenger seat is occupied. This sensor consists of a construction in which two sheets of electrodes sandwich a spacer. When the occupant is seated, the electrode sheets come in contact with each other through the hole that is provided in the spacer portion, thus enabling the current flow and detecting whether or not an occupant is seated in the front passenger seat.
Lex
Originally Posted by MR LEX
You can also disable this by doing the following:
Lex
Lex
Now for the technical explanation
Lex
Lex
sheriffwoo
06-12-15 08:28 AM
