IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Cam Gears
Old 03-26-15, 07:33 AM
Dirkis41
Dirkis41's Avatar
Default Cam Gears
Is anyone using the Fidanza adjustable cam gear? I'm looking into them and their $230 for the pair. I also found some on Ebay for $70 for the pair(DPT motorsport). Why would there be such a price gap if they are both made out of aluminum??
Old 03-26-15, 07:56 AM
drft_n_sc
drft_n_sc's Avatar
If I'm correct, you should only have to buy the exhaust side since there isn't an adjustable cam gear for the intake side (the IS is a VVTi motor)
I've seen the can gears go for as low as $80
Hope this helps
Old 03-26-15, 08:03 AM
Dirkis41
Dirkis41's Avatar
Yes that is correct, I only need the exhaust side but its also an aesthetic thing. I want it to match...
Old 03-26-15, 08:26 AM
drft_n_sc
drft_n_sc's Avatar
powerdynamix.com will color match your VVTi cam to look like your aftermarket exhaust cam since you won't be able to buy an aftermarket one
jdmteeth
Maintenance
02-16-11 09:03 PM
fordsvtmfl
10-16-08 07:58 PM
Gs3PoweR
Performance
05-12-03 01:57 PM
RysBURNER
Performance
02-19-02 07:42 PM
Quick Reply: Cam Gears
