IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
plz help my heater is killing me
Old 01-14-15, 02:49 PM
givm2me360
givm2me360's Avatar
Default plz help my heater is killing me
so here is my issue ,lets say I want to set my heater temp at 72 , its blows super hot and temp doesn't change until I turn it down to lo, but when I do that it turns cold there is no in between temp control at all , not sure what this can be I know its not thermostat, cause then it would always be hot. I called lexus and they aren't willing to help me over the phone they want my money
Old 01-18-15, 10:37 PM
rvalero
rvalero's Avatar
Have you ever removed the panel under your steering wheel? If so, there is a blue plug by the driver's right knee. Of course, you can only see it if you remove the panel/swing it down, There should only be a couple screws holding it in. If it's not plugged in, it will seem like your air-mix servo isn't working.
Old 01-19-15, 02:18 AM
givm2me360
givm2me360's Avatar
ok yea i will check i havnt taken it off so im not sure but thankyou and ill let you know if this was the problem
Old 01-19-15, 02:24 AM
rvalero
rvalero's Avatar
If that isn't it, there is probably a problem with your air-mix servo.
Old 01-26-15, 02:52 AM
givm2me360
givm2me360's Avatar
Is the air mix servo, a common problem and can i fix it myself ?
Old 01-26-15, 09:18 AM
rvalero
rvalero's Avatar
Check out this thread: http://my.is/forums/f115/anyone-repl...-steps-392877/
Abernoots
03-06-18 07:54 AM
Zooming993
GX - 1st Gen (2004-2009)
10-12-13 08:07 PM
halac
02-15-13 03:30 PM
Twicked1
01-16-06 11:22 AM
Tag129
10-04-05 11:47 PM
Quick Reply: plz help my heater is killing me
