IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Check engine light problem!
Old 12-08-14, 07:34 AM
rogal
rogal's Avatar
Default Check engine light problem!
So i have a check engine light on and the code is po113, I've tried clearing the light but it won't go off. I even disconnected the battery for 15 minutes. Even if the a sensor is plugged out the light should still clear for a minute or two is what I was informed of.
I looked up the code and found this out
- Faulty Intake Air Temperature (IAT) sensor
- Dirty air filter
- Intake Air Temperature (IAT) sensor harness is open or shorted
- Intake Air Temperature (IAT) sensor circuit poor electrical connectio
has anyone had this problem before?
Old 12-10-14, 04:58 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
Most likely a bad mass air flow sensor - it houses the intake air temp sensor as well.
if you had access to a bluetooth obd2 reader and an app like Torque, you could look at the reported intake temp and see if it jives with what it should be.
Old 12-15-14, 02:07 PM
LeTechSpec
LeTechSpec's Avatar
mitsuguy is correct. The IAT is with the MAF. You can try cleaning the MAF with MAF cleaner. You can get one in any Auto Part store.
Michael88
08-20-18 02:35 PM
SautoIS350
10-09-13 02:03 PM
sagarx
02-26-11 08:33 PM
cgholson
07-17-08 05:28 PM
palaka
RX - 1st Gen (1999-2003)
05-23-08 05:39 PM
Quick Reply: Check engine light problem!
