2007 Lexus IS 350 Head Lights issue
I have a 2007 Lexus IS 350 with 99000 miles I bought it about 7 months ago. I have this issue where the headlight goes out after a period of driving. I start it it turns on than it will shut off after maybe 5 minutes of driving.. Its the drivers side. So i bought new light bulbs at first replaced them and It did the same thing. Work for 5 - 10 minutes than shut off. I can turn my headlights off and on real quick again and they stay on some times for hours.. some times 2 minutes mostly just turn off after about 5 minutes. So I did a little more research. I was told try replacing the ballast. So I ordered a OEM Ballast. Replaced it on the headlight and bam still does the same thing. At that point I was getting a little mad. So I changed the headlight bulb from drivers side to passenger side.. It worked for over a week didnt have any issues. Now its doing it again. Sometimes when the lights go to turn on automatically both lights wont turn on... I have to switch them off than on again then the drivers will die after 5 minutes again. I really dont understand anyone have anything like this.. please help.
That is the exact issue my mother is having on her 07 Toyota Solara SLE with HID's, all stock. We replaced bulbs and ballast, all oem. Still got the issue. Read a bunch about Prius owners having the issue as well...
Try swapping the bulb to the other side and see if the problem switches sides as well. Usually the issue is a bad bulb, they will ignite, but then go out shortly after and will reignite when you turn them off and back on.
gotta be careful with what you are buying. i bought a bulb off of amazon once and if i wasn't as picky and **** as i am i would have never noticed that the bulb was used. looked clean but when you looked closely at it there was a little dirt in crevices. after reading the sellers feedback turns out it was a common thing.
tbarrios
09-29-18 04:42 PM
