IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
lowered, what do i need for correcting camber?
Old 07-20-14, 02:46 PM
10ac
3rd Gear
10ac's Avatar
Default lowered, what do i need for correcting camber?
i have a 2002 lexus is300 sedan. i just installed Tein s-tech lowering springs and Tokico HP Blue struts all 4 corners. My camber is not correct. Took to alignment shop and it needs to be adjusted more. it leans out at the bottom and leans in at top. i wanna correct it. same for front and rear.
what parts do i need and best prices to get them? only thing i have found is SPC Balljoints for the front upper, and SPC cam bolt kit for the rear lower arm area and found them on ebay.
will those parts be good or will i need something else? remind you i will not be lowering anymore than what it is now. i am new to the is300 scene by the way, so any help will be appreciated.
Old 07-23-14, 11:19 AM
edmorl
edmorl's Avatar
upper control arms ?
Old 07-24-14, 01:02 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
Yes, your parts list will work. You can also look into Figs engineering, Mike makes some nice suspension parts... look into roll center adapters while you are at it
Hyper15125
04-21-18 03:42 PM
Meraki Autoworks
CL Vendor Products for 3IS
08-19-17 06:10 PM
Jlok619
Suspension and Brakes
05-16-14 10:38 PM
carchitect
22
01-02-12 04:53 PM
VIPJOSH
03-19-09 12:17 PM
Quick Reply: lowered, what do i need for correcting camber?
