IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
VVTi Cam Issue?
Old 06-03-14, 02:37 PM
Exia
Exia's Avatar
Default VVTi Cam Issue?
After a HG replacement, I got the engine back together and everything seemed fine, except a vacuum leak near the intake and a whining sound now coming from the VVTi cam.. Any idea's on what I need to look for here?
Old 06-04-14, 08:06 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
are you completely sure its the VVTI gear? there are lots of other things in the area to isolate first... I would take the serpentine belt off first and start and run the car and see if the noise goes away or changes... I would suspect power steering pump or similar before the vvti gear - it is a pretty simple piece and I've never seen nor heard of one making any noise...
Old 06-04-14, 10:54 PM
Exia
Exia's Avatar
You maybe right I know when I slightly turned the steering wheel she groaned bad, I will find out tomorrow if its not raining and see how it goes, but its weird cause the car made no sound period prior to tear down, now after the HG replacement its not sounding good
Old 06-06-14, 09:00 PM
lacroix
lacroix's Avatar
if power steering pump was removed , u must bleed it by turning side to side and filling while engine running.
Old 06-06-14, 11:20 PM
that2JZguy
that2JZguy's Avatar
^^ This.
Put the front wheels up in the air and turn from all the way left to all the way right over and over again with the car running and add fluid if needed. If it's the pump itself making the noise you may have starved it of fluid at startup and burned it out. If it's the rack then you just have air in the system and need to get it out.
Old 06-10-14, 04:58 PM
Exia
Exia's Avatar
Yep, I was to busy freaking out i did something wrong, I just let it run turn the wheels back and forth she's as quiet as a mouse..
soflo99
Performance & Maintenance
12
09-03-13 10:31 AM
GTESCTHREE
SC- 1st Gen (1992-2000)
03-26-11 01:46 PM
lpolo69
02-11-09 06:54 AM
UptownGS
Maintenance
09-14-05 05:32 AM
kmn5
06-05-04 10:05 PM
Quick Reply: VVTi Cam Issue?
