IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
p0430 code ... which cat is bad?
Old 12-28-10, 05:19 PM
luckytaxi
luckytaxi's Avatar
Default p0430 code ... which cat is bad?
02 IS300 w/ 130k miles - EVERYTHING is stock
Over the summer I replaced both the header and ypipe with parts from ebay (salvage cars). Initially I had a p0420 code and took care of everything along with 3 of the 4 o2 sensors. The only o2 sensor i didnt replace was the B2S1 sensor due to it arriving late from California. Fast forward to earlier this week. Now I'm getting a p0430 code! I understand this could be an o2 sensor going bad, if so would that explain maybe the B2S1 sensor since I never replaced it?
If it is indeed a bad cat, would it be one of the two in the manifold or the one on the ypipe?
Old 12-28-10, 05:23 PM
ais300c
ais300c's Avatar
I think u only got one homie
luckytaxi
luckytaxi's Avatar
Doesnt the is have 3? Two in the header manifold and one on the ypipe?
Old 01-02-11, 07:15 AM
FranksES
10th Gear
FranksES's Avatar
Default P0420, p0430
Lucky,
P0430 refers to the bank 2 catylist. On the IS300, thats the cat which takes care of cylinders 4,5, and 6 (the second one on the header). Before replacing any sensors, make sure you have NO exhaust leaks at the header/exhaust pipe connection, as any leak could cause the code to set.
Old 01-02-11, 06:18 PM
luckytaxi
luckytaxi's Avatar
What's the code for the ypipe's cat? Bummer as I replaced both the header and the ypipe with parts from salvage cars. I'm hoping that the B2S1 is the reason why that code keeps appearing. it's the only o2 that wasn't replace.
Old 01-03-11, 06:53 PM
FranksES
10th Gear
FranksES's Avatar
Default Code for ypipe converter
There is no code for that. I don't think that's a catalyst. P0420 refers to the cat for cylinders 1,2,and 3. P0430 is for 4,5, and 6. Both are in the header.
Old 01-03-11, 07:45 PM
IS3_FTW
IS3_FTW's Avatar
Definitely check for leaks. Did you replace the gaskets?
P0430 is bank 2(cyl 4,5,6) catalyst is going bad. Thats the headers closest to the firewall. Sorry bro, wish it was that B2S1 sensor.
Here is a code list...
http://my.is/forums/f87/obd-codes-list-326733/
Old 10-15-13, 03:46 PM
TrueGiant
TrueGiant's Avatar
im new to cl but im having the same code thrown at me (P0430) and a P0440. i cant pass smog and i have no idea what i need to do or should look at. any help?
Old 03-27-14, 04:19 PM
striderg3
striderg3's Avatar
I have the same code on my GS430 (2006)
did OP's problem get solved by replacing one or both cat converters?
Old 03-28-14, 08:04 AM
Black1129
Black1129's Avatar
I had those codes two weeks ago.. One of the two up front car broke in pieces and got clogged at the cat in the back so I bought the who exhaust from a parted is300 and got the sensors with it.. Complete exhaust cost me 250 and it was a cheaper fix then buying a brand new one for getting the cars replaced. So start with a leak first if nothing. At night take the car for a spin and get it high rpm's then quickly in a dark area check all three cats if they glow red. That's a sign of a bad cat. If it's the one of the two up front replace it quick or you'll have two bad cats if you don't!
flyboyplo
05-09-14 08:30 AM
unadad
RX - 1st Gen (1999-2003)
11-25-13 07:01 PM
chi123
Maintenance
08-27-12 07:19 AM
chi123
08-14-12 06:27 AM
UncleRay
Maintenance
03-06-08 05:13 PM
Quick Reply: p0430 code ... which cat is bad?
