IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
M mode flashing help please
Old 03-14-14, 07:23 PM
Black1129
Black1129's Avatar
Question M mode flashing help please
My m mode flashes on cluster when I put into gear.. Why is this could anyone help please?
Old 03-15-14, 12:15 PM
bryan12887
bryan12887's Avatar
I have the same Problem 05' A650E Flashing "M" on manual mode wont change gears .. works perfect in "D" mode
Old 03-15-14, 10:16 PM
IS3Jay
IS3Jay's Avatar
this was happening to me when the pedal position sensor went bad on my car
Posted from ClubLexus.com App for Android
Old 03-17-14, 07:40 PM
Black1129
Black1129's Avatar
This is how my m mode started working. My car to the beach got into some traffic and I've noticed my fan turn on and instantly smelled coolant but no overheating or steam. Checked it the next day and seen dry coolant marks around the top of the radiator and the fan also splashed some around. So I turned the car on and let run till the fans turned on and quickly checked for leaks. Noticed my radiator cap had a leak. Replaced it and then at a stop light switched to m mode and it worked
Old 03-17-14, 08:00 PM
Brolic
Brolic's Avatar
Your motor bout to take a **** on you. Heads up.
Old 04-21-14, 08:39 AM
bryan12887
bryan12887's Avatar
anymore possible causes/solutions !?
Old 04-21-14, 11:32 AM
Black1129
Black1129's Avatar
Yeah bro just gotta replace the bad solenoids under the tranny pan. Some people play around with the connections on the solenoids but at the same time some say it's a temp fix
https://www.clublexus.com/forums/gs-...tml?styleid=14
Old 08-05-14, 11:50 AM
bryan12887
bryan12887's Avatar
Default solved "flashing Mode"
Steering wheel button shift assembly button down was broken on the inside
Ihussain
06-16-18 04:43 PM
SC2JZ300
01-29-14 12:54 PM
alladien
12-16-13 08:16 PM
crapoud
07-21-10 09:40 PM
BostonGS4
08-18-04 08:00 PM
Quick Reply: M mode flashing help please
