IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
2001 Lexus IS 300 Not Starting
Old 03-14-14, 04:11 PM
Ryanren
Ryanren's Avatar
Default 2001 Lexus IS 300 Not Starting
I have 2001 lexus is 300, that will not start it will turn over put won't catch and start. I need help because I am running out of ideas. I have replaced the fuel pump, fuel pump regulator, spark plugs, coil packs, gaskets, wires and did an oil change. There was oil on top of spark plugs so I replaced gaskets. The car stopped running a month and a half ago it stopped running when it was put in reverse and didn't want to start. It randomly started during the month and half it been down. So basically I am confused about what is going on....please help.
Old 03-21-14, 05:17 PM
AspenCdn
AspenCdn's Avatar
Sounds like an electrical issue. Do you have a CEL?
Are you getting spark? Could be a bad crank sensor or cam sensor.
You have already spent a lot and could end up spending more chasing the wrong thing. It might be time to bring it to a pro shop.
Old 03-27-14, 10:56 PM
PIONEER
PIONEER's Avatar
were all the parts replaced a month and half after it stopped running or it ran for a month and half after the parts replacement and then stopped running?
check codes and see what the errors are.
Old 03-28-14, 08:37 AM
Black1129
Black1129's Avatar
Did you even test the starter? Pull it off and take it to a auto zone to get it tested (FREE!)
If that didn't work. The three main things for a engine to start are spark,fuel and compression
Old 03-28-14, 08:38 AM
Black1129
Black1129's Avatar
And please check your fuses and relays
Old 07-17-14, 06:01 PM
tuner79
tuner79's Avatar
I'm having the exact same issue. Ever find out the cause??? So far I've replaced the fuel pump.
pakiman626
04-18-23 12:13 PM
tenac2215
Performance & Maintenance
13
07-20-20 05:19 AM
LexusTechn
06-30-19 09:06 PM
edsautoacc
Build Threads
11-16-14 12:23 PM
lsflame
11-13-06 07:28 PM
Quick Reply: 2001 Lexus IS 300 Not Starting
