IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Vibration from steering wheel when braking
Old 03-02-14, 06:40 AM
JabZ
JabZ's Avatar
Default Vibration from steering wheel when braking
Have replaced the control arms, and also a new tire and wheel balanced but the problem is still there. Ive been told the rotors and pads are fine so bit confused on where to go next? any help would be great.
Also when my tire was off this had some play in it, its circled in red in the picture:-
Old 03-02-14, 03:54 PM
is3wagon
is3wagon's Avatar
Does steering wheel shake faster at highway braking and less at slow speed stops? Did you check caliper slides and pads move freely in caliper bracket shims? If so, put ur rotor on a lathe and check for trueness.
Old 03-04-14, 04:55 PM
Supraguy88
Supraguy88's Avatar
If it only shakes when braking then its more than likely warped rotor issue. Could also be a lower control bushing. The circled in red part is the sway bar and that should not have a shacking effect under braking
Old 03-06-14, 02:56 PM
PIONEER
PIONEER's Avatar
Put 1 wheel in the air at a time. Move the wheel left and right and see if there's play in the suspension. Could be the tie rod, Did you replace both the upper and lower control arms?
Old 03-07-14, 08:30 PM
redsx
redsx's Avatar
Put a dial indicator on the brake rotor and check for runout. Also, inspect the brake rotor for heat spots.
Old 03-13-14, 08:48 AM
KCCOAbel
KCCOAbel's Avatar
being that the cost of pads and rotors is not so expensive, i would just go ahead and replace the pads and rotors.
Old 04-01-14, 07:27 AM
MahLex
MahLex's Avatar
Either warped rotors, i had same problem and my pistons were bad in the caliper, so it caused one of the wheels to "brake" all the time. Lift ur car, spin the rotors, the press the brakes, and check if any of the rotors get stuck.
Old 10-17-14, 12:14 AM
twinzdad07
twinzdad07's Avatar
did the car ever had an accident? my old is had a salvage title and the tires in the rear gets worn out way quicker
Old 10-21-14, 07:14 PM
plazalexus
plazalexus's Avatar
Default warped rotors
Even if there is a slight warping of the front rotors (not even visible by the naked eye) you will feel it in the steering wheel when braking. Recommend you replace the frint rotors and pads to have all new braking surfaces. Also check and clean and lube all caliper slides and pad slides. If you feel the vibration in your seat then it is the same situation in the rear brakes, follow the same procedure above for the rears. I knkw this from experience and I am a technician...
Old 11-03-14, 08:46 PM
Diehl927
Diehl927's Avatar
Lower control arm bushings, I've got the same problem, check your inside tread on your front tires , see if they're wearing unusually fast
gazi001
RX - 1st Gen (1999-2003)
17
01-22-13 12:00 PM
randee973
02-05-12 03:53 PM
sivikvtec
Suspension and Brakes
07-03-11 08:32 AM
JohnLX300
16
02-12-10 12:19 AM
luciano
16
06-02-06 04:10 PM
Quick Reply: Vibration from steering wheel when braking
