IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Car starts but dies when accelarator is pressed
Old 02-14-14, 04:54 PM
JesLet
JesLet's Avatar
Default Car starts but dies when accelarator is pressed
Just got done with my engine swap for my IS300 ( Same 2JZGE vvti engine ), took a while to get it started. Finally ran but when I pressed the gas pedal car dies immediately. I am meticulous about every single wires on this engine. I don't know what else could it be. I'm suspecting its the throttle cable position sensor.
It is the same throttle body from the old engine so i know it works. Or i probably mess it up by cleaning the assembly with brake cleaner.
Old 04-16-14, 07:04 AM
LEDHI
LEDHI's Avatar
Could be ignition coil, cylinders or spark plugs...not firing up
Old 04-17-14, 07:07 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
Not a good idea to clean dbw throttle bodies with any sort of spray cleaner... Chances are you fubared the tps and/or the throttle motor...
Old 04-17-14, 08:41 PM
PIONEER
PIONEER's Avatar
could be idle air control, throttle position sensor, if you removed it from the throttle body, did you put it back properly using a feeler gauge?
Indangasi
01-22-19 12:30 AM
Cp2295
11-26-16 12:24 AM
Cure
Performance & Maintenance
08-08-14 09:04 AM
LSPiNoY
10-14-04 12:00 PM
TRULUX
09-01-04 08:53 PM
Quick Reply: Car starts but dies when accelarator is pressed
