IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Coolant Temp Sensor.
Old 01-22-14, 11:04 AM
vteckiller
vteckiller's Avatar
Default Coolant Temp Sensor.
Hello all, first off Im new to Lexus forums. so Im not sure if this is the correct spot to post this. i have an 2001 Lexus is300 and i need to do the coolant temp sensor but having difficulty locating this sensor. any help with areas, pictures, locations to look would be greatly appreciated. thanks. -Mike, k.
Old 01-22-14, 01:25 PM
neosxe808
neosxe808's Avatar
located on the bottom of the radiator, on the passenger (right side). Its a white plastic sensor that needs to be unplugged before you remove it, with an adjustable wrench, 2-5 minute job.
Make sure you do it when the car is cool, and be sure to have a pan underneath as coolant will leak out......
Old 01-22-14, 04:10 PM
vteckiller
vteckiller's Avatar
Thanks, yeah did the O2 sensors. the one by the firewall. very tricky. lol. next is this temp sensor been hounding me. i looked and looked.. thanks again. im going to do it tomorrow as it is like 30 degrees outside. and nearing dark.
Old 01-23-14, 12:39 PM
Jewel707
Jewel707's Avatar
does anyone happen to have the part number for the coolant temp sensor?
RJ1968
02-02-18 02:35 PM
mjr955201
Performance & Maintenance
06-08-16 12:29 AM
LeftSideES
03-27-16 12:35 PM
jensIS300
Performance
10-28-12 07:02 PM
Haus
08-03-10 09:47 PM
Quick Reply: Coolant Temp Sensor.
