IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
05 Lexus Is300 (Center Console is NOT blowing air)
Old 01-07-14, 05:26 AM
Sg85is300
Sg85is300's Avatar
Default 05 Lexus Is300 (Center Console is NOT blowing air)
Hi everyone,
New to CL. I wanted to know why my center console does Not blowout any type of air but the other two DOES. Air conditioning is working fine but every time I put the air the vent throws out cold air and fogs up my front windows all the time. Can someone please help or give me a tip what could be the problem thanks lots
Old 01-07-14, 01:41 PM
neosxe808
neosxe808's Avatar
pull out the center vent console and see if the black plastic snorkels directing the air flow is present or missing.
if they are, could be a problem with the climate control unit itself........
Old 01-07-14, 10:49 PM
Jaybeck860
Jaybeck860's Avatar
I just started having the same problem two days ago... it just randomly stopped coming out. I hope someone has an answer
Old 01-08-14, 07:44 PM
aneidiaz
aneidiaz's Avatar
Sounds like you guys are having SERVO problems..... MODE servo at that... The one that controls WHERE your air is coming from in the vents (head to feet to head+feet). Here's a DIY link from the 2GS department... But it might be too far off from what it may look like in your car guys..... Oh btw, read EVERYTHING very carefully then SEARCH for a thread that is specifically for you guys ok? If you shall want OEM Lexus servos, go to www.sewellparts.com, sign up, and add your CL account for GREAT DISCOUNTS!!!! Anyhow, here's the link I mentioned above.....
https://www.clublexus.com/forums/gs-...vo-motors.html
Stereorob
20
08-08-21 08:26 PM
koolina13
Performance & Maintenance
12-20-18 01:07 AM
Sg85is300
Performance
03-10-14 06:06 AM
SteveH
RX - 1st Gen (1999-2003)
01-09-04 07:13 PM
Quick Reply: 05 Lexus Is300 (Center Console is NOT blowing air)
