IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Vibrations when I drive, what could it be?
Old 12-31-13, 05:51 PM
MahLex
MahLex's Avatar
Default Vibrations when I drive, what could it be?
Hey guys, when I'm gng arnd 45 mph and 65 mph, my steering wheel vibrates when I let it go. When I'm gng 65+ mph it doesn't! between 25-45 it vibrates slightly, and under 25 it doesn't either. Any thoughts?
Old 12-31-13, 05:53 PM
HellaInc
HellaInc's Avatar
Are you running spacers? Maybe you need your wheels balanced and aligned?
Old 01-02-14, 11:01 AM
is3wagon
is3wagon's Avatar
Get them on a tire balancer. Then you will know if its a bent rim, bad spot on the tire or a balance issue. Good luck
Old 01-02-14, 05:12 PM
MahLex
MahLex's Avatar
No not using spacers, I got it balanced, improved a tad bit in turning and grip. I'll get my alignment soon, hopefully that does the trick.
Old 01-02-14, 08:18 PM
aneidiaz
aneidiaz's Avatar
Might wanna also Jack the car up bro. Just take a look all around the bottom. You know a conscious visual inspection.. maybe brakes, ball joints(see if they're loose; needs to be replaced), outer tie rods, etc). Just to be on the safe side. Sometimes it can just be ball joints or certain pattern of wear on the rotors & pads. Also, when you get it aligned tell the technician to check em out as well. Good luck bro! Hope this gets resolved fully!
Old 01-03-14, 05:44 AM
MIS300
MIS300's Avatar
My experience has been the major contributors to steering wheel vibrations are:
1) Tires
2) Rotors
3) Tie Rods and Ball Joints
4) Front End Bushings
5) Wheel bearings
Tires will usually clean things up, especially since they get balanced by the install shop, but there could be an underlying problem and the tire's uneven wear is just a symptom. Rotors tend to vibrate more when braking but can still contribute. Tie rods, ball joints, and front end bushings seem to go start showing wear anywhere from 80-120k miles. This is not limited to the IS300, just cars in general. Depending on how bad they are, they can make a car feel completely different when replaced. I threw wheel bearings in there because after replacing all the above, you might as well : ^) Good luck and report back when you resolve your issue.
Old 01-04-14, 02:11 PM
MahLex
MahLex's Avatar
Ok thx guys, will get back with the solution hopefully!
Old 01-06-14, 08:44 PM
MahLex
MahLex's Avatar
It was the tires, gonna get a new set of Kumhos this week, and that should fix it!
Old 01-07-14, 12:10 PM
aneidiaz
aneidiaz's Avatar
Still have somebody check out the condition of the front suspension components bro. Just to be on the safe side.
Old 01-07-14, 01:58 PM
MahLex
MahLex's Avatar
Lol, got my tires and nope not the reason. So much for to technicians saying its a 90% chance it's tires! yep getting my car inspected tomorrow.
Old 01-07-14, 05:40 PM
aneidiaz
aneidiaz's Avatar
Get lower ball joints and outer tie rods put on bro. I'm not telling you to bank on that but there's a more then 50% chance that'll fix the problem. With a good alignment. Relatively cheap repair.
Old 01-08-14, 08:51 AM
MahLex
MahLex's Avatar
My mechanic said its the Tie Rods so I ordered inner and outer tierods from rock auto. He said its alright to drive tho, since its in its early stage of going bad. Better be those damn tierods tired of running back and forth lol.
Old 01-08-14, 02:25 PM
cura
cura's Avatar
Are u running with stock rims i had the same problem lugnuts wasnt the original for the rims car vibrated at speed of 65
Old 01-08-14, 02:59 PM
aneidiaz
aneidiaz's Avatar
I hope you ordered them MOOG bro. Those the best. Not expensive at all either. Doesn't matter where you buy them from. They're relatively cheap off any site.
Old 01-08-14, 05:52 PM
NMTIS300
NMTIS300's Avatar
Could be a bent wheel. One of my enkeis is maybe 1/32" out, and it has a little shimmy on the highway. Could also be weird tire wear.
Quick Reply: Vibrations when I drive, what could it be?
