IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
is300 p0011
Old 10-07-13, 10:44 PM
isaua
isaua's Avatar
Default is300 p0011
Hi all I'm new to lexus...
I've a is300 47500 miles on it automatic, engine idles 1000rpm when the a/c is on 1200 rpm.
Check engine is light on, trac off flashing and the car have lack of power, when flooring it it seems that the vvti is not kicking in.
The car has aem cold air intake and new maf sensor.
The code that it throws is p0011 camshaft timing over advanced bank1.
I took the ocv off put it on power and ground and it click and moves ok.
What I can see is there is a small thin tube by the head under the ocv , looks like a vacuum pipe, but it's open no hose goes to it is that nnormal?
What else can I do to fix this problem?
Old 05-25-15, 02:05 PM
Davids2jz
Davids2jz's Avatar
Default Same here
Im having the same problem after doing my timing belt. I think it's the vvti cam gear. Any suggestions? Did you fix yours?
Rockhound1
03-04-19 08:11 AM
jjoh
09-06-17 05:36 PM
Lexxxis300
Performance
02-24-15 09:09 AM
eghatch15
06-04-13 02:37 PM
jeffriesj
11-04-12 03:47 PM
Quick Reply: is300 p0011
