IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
cool, cheap stuff for your is300.
Old 04-23-13, 11:53 AM
Dtcsurfer
Dtcsurfer's Avatar
Default cool, cheap stuff for your is300.
yes i want to make my car look good/ run better and im not that kind of person that can go spend a ton of money everywhere.. what are some ideas that i can do for cheap that can give some taste to my car?
Old 04-23-13, 02:02 PM
bl3ujay07
bl3ujay07's Avatar
Clean up the headlights. Make the car look that much nicer.
Old 04-23-13, 02:10 PM
Dtcsurfer
Dtcsurfer's Avatar
whats the easiest way to clean the headlights? ive tried kits before but they dont work
Old 04-23-13, 08:45 PM
RobnBlue
RobnBlue's Avatar
what kind of budget you looking at?
Old 04-23-13, 09:11 PM
Dtcsurfer
Dtcsurfer's Avatar
around 200 to 300 dollars?
Old 04-23-13, 09:20 PM
RobnBlue
RobnBlue's Avatar
Air Intake's run about that much, strut tower braces run about $100, and some axle-back exhaust systems run around 200-300$.
Exterior, there are some bumbers n lips that run around $300.
but i'm not too sure if thats what you were looking for lol
Old 04-24-13, 11:20 AM
bl3ujay07
bl3ujay07's Avatar
Before I bought my DA polisher, i bought the 3M kit and it worked. A polisher yields better results but using the drill kit works well too. It will definitely be an improvement.
I say if you have a drill (strong drill much better imo), buy a DIY headlight cleaning kit, a 3M wet or dry 1000-2500 grit variety pack of sand paper, and optional 3000 grit trizak pad (although i believe the kit will come with one already) which will make a big difference from my experience.
Tape around the headlights (I say two layers of tape to make sure), clay headlights if you do have clay bar, and start wet sanding. From the picture I saw you posted earlier, your headlights don't look REALLY bad, so I say start wetsanding with 1000 and slowly work your way up to 2500 and then the trizak. Lastly, polish! I am no expert, but it works out really well for me. Have done several headlights and they all come out looking MUCH MUCH better.
Old 04-24-13, 12:12 PM
Dtcsurfer
Dtcsurfer's Avatar
i already have a full cat back exhaust system and a AEM air intake
Old 04-24-13, 12:14 PM
Dtcsurfer
Dtcsurfer's Avatar
thanks man! I am also going to take the glass off the headlights to paint the light frame black. i just clean the glass up then. hopefully my headlights are gunna be looking real good!
Old 04-24-13, 04:52 PM
RobnBlue
RobnBlue's Avatar
gotcha bud, keep up the good work
Old 04-27-13, 09:05 AM
bacon22
bacon22's Avatar
The lens is plastic. becarfull with the tabs they break easily i broke one and hate seeing it everytime i look at my headlites but the mod is easy. the hardest part is cleaning out all the sylicone but i jus kept putting it back in the oven and scrape till its hard again and repeat the process. flat head and a knife work great. Make sure when ur putting it back together u have a solid amount of sylicone in there u dont want any hole to form. then ull have to tear the whole thing apart again. couple tips to help u out.
Old 04-27-13, 11:56 AM
Dtcsurfer
Dtcsurfer's Avatar
thanks man! helps alot!
Chris1020
05-07-14 12:03 PM
jaseman
10-27-13 08:51 PM
evanis300
01-02-10 04:29 PM
Faymester
05-22-07 06:41 AM
JohnnySC
SC- 1st Gen (1992-2000)
01-03-02 01:00 PM
Quick Reply: cool, cheap stuff for your is300.
