IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Lower Ball Joint "Creaks for Help", What Else Should Changed!
Old 07-30-12, 06:07 AM
badbwoy007
badbwoy007's Avatar
Default Lower Ball Joint "Creaks for Help", What Else Should Changed!
Just picked up a 2001 IS300 with 123K. I know the lower ball joints will need to be replaced. What else in that are should I just change out while tending to the ball joints?
Old 07-30-12, 08:35 AM
DonCorleone
DonCorleone's Avatar
Suspension wise? jack the car up and look at the bushings for cracks or wear; lower control arm, upper control arm, tie rod ends, sway bar bushings, motormounts, check the shocks to see if they're leaking, inspect the brake lines for cracks.
At that mileage, make sure the timing belt service has been done, if not, do it asap. I'd also flush the fluids; power steering , brake, coolant and transmission fluids.
Old 07-30-12, 06:47 PM
SuthrnGent
SuthrnGent's Avatar
Sway bar endlinks and swaybar bushings are also suspects for creaking over time
Doublebase
09-25-17 03:11 PM
Leja145
Suspension and Brakes
05-04-17 04:43 PM
HotBoy
17
04-15-04 01:36 PM
persian451
07-13-03 12:28 AM
Quick Reply: Lower Ball Joint "Creaks for Help", What Else Should Changed!
