O2 sensors bank one and two
I have a modified exhaust from the headers straight back. My check engine light and trac light come on every so often is there any fix manually or buyable that i can use to remove this?
I went to a autozone to get the codes pulled which hey do free. The worker stated that my o2 sensors for my exhaust were the codes coming up. I have after market headers as well as a straight back exhaust from there. The o2 sensors are on the pipes but i doubt they will ever read fine with this setup.
It would help a lot if he gave you the codes.
I just installed Megan headers and Downpipe and I've been get Codes P0420 and P0430. Did a DIY O2 sim for the downpipe, its been over 300 miles and no P0430. Now I need to do it one of my other sensors to get rid of P0420.
thanks
http://www.s10forum.com/forum/f89/do...4/#post6787210
I followed this here. Its another forum. I used parts 42009 that comes with washers. it was $5-6 at autozone. I would say get the others one with no washers n save yourself $2. I ended up using only 1 for the megan downpipe cuz of space. Took maybe about 5mins just to do this.
here's a pic of codes n what sensor. Got this from my.is.
I'm going to add this 2 my header since I'm getting code P0420. I'm going to see if this helps. Its cheaper than the Megan one that u can buy.
