IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
1JZ no spark!? helpp!
Old 07-12-12, 01:14 PM
1JZjackson
1JZjackson's Avatar
Default 1JZ no spark!? helpp!
I have a 1JZ I am not getting any spark. I have power to my coils both pins have constant power. is that correct?? any help or suggestions would be appreciated. is there a way to test my igniter?? help me out guys!!!
Thanks!
Old 07-12-12, 01:18 PM
vrmRollLex
vrmRollLex's Avatar
can you ask a friend that maybe has an is300 to test?
try checking your fuses too?
Old 07-12-12, 01:21 PM
1JZjackson
1JZjackson's Avatar
I have one of the only 1jz's around my area. I've been reading a lot of the cam and crank sensors. any suggestions?
Old 07-12-12, 01:27 PM
93MSB
93MSB's Avatar
yes both pins will have 12v power, the ecu grounds the circuit. Definitely check the crank and cam sensors by doing a resistance test, and also check the continuity to make sure the ecu is getting a signal from them. It could also be possible you have a bad ignitor or ecu
Old 07-12-12, 01:44 PM
1JZjackson
1JZjackson's Avatar
Could it be that i dont have enough engine grounds? i have a chase bays harness and it is wired to an aristo 2j ecu.
Old 07-12-12, 02:55 PM
93MSB
93MSB's Avatar
Im not familiar with the chase bays harness, the factory harness has two grounding points on the intake manifold.
on the factory harness the cam and crank sensors are grounded to the E11 wire/pin. make sure the E11 and all the other "E(x)" pins at the ecu are getting continuity at the intake manifold ground(s)
Old 07-12-12, 03:17 PM
1JZjackson
1JZjackson's Avatar
maybe thats it. i have no intake manifold grounds. i could just be lacking ground continuity. I only have a ground through chasebays harness and a ground going to the firewall from the cyl head. hopefully thats the problem.
Thanks!
Dtaylor3
Performance & Maintenance
14
06-29-15 02:40 PM
speed6
09-24-13 02:19 PM
Ken C.
10-29-11 09:51 AM
trevor10
05-05-10 07:01 AM
Rising_Sun
19
10-01-05 11:08 AM
Quick Reply: 1JZ no spark!? helpp!
