IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Stock alarm makes no arming beep?
Old 07-04-12, 08:20 AM
smajroh1
smajroh1's Avatar
Default Stock alarm makes no arming beep?
I have 2004 IS and I noticed when I press my lock button on my remote it doesn't beep. If I unlock it, it will beep twice like normal. But it will not beep when I try to press the lock button. If I have the headlights on and I press the lock button twice the lights don't turn off like they did before. This is a stock alarm with the stock key.
Any recommendations?
Old 07-04-12, 08:58 AM
plus1choi
plus1choi's Avatar
i do not pay attention much to beeping when i arm my car, so not sure about that. might be somewhere in owners manual. but for the headlights make sure its on the auto setting and after arming twice lights will go off
Old 07-04-12, 11:28 AM
smajroh1
smajroh1's Avatar
Before when my alarm beeped when I locked it, it didnt matter if my headlights were on auto setting. If I pressed the locked button twice and my headlights were on they turned off. I think its something with the alarm.
Old 07-04-12, 11:45 AM
smajroh1
smajroh1's Avatar
I just noticed it does not lock the driver side door.
Old 07-04-12, 01:57 PM
Juic
Juic's Avatar
It is most likely your servo motor for the lock.
Old 07-05-12, 07:18 AM
smajroh1
smajroh1's Avatar
I was told its my actuator.
Old 09-15-12, 10:50 AM
MyLittleIS
MyLittleIS's Avatar
I am having a similar issue... do your doors all lock when you press the arm button?
Old 09-15-12, 03:56 PM
2JZSteven
2JZSteven's Avatar
i got the same problem, one of my friends said i should get the fuses because this started to happen after i changed my battery
Old 09-16-12, 10:17 PM
Misitified
Misitified's Avatar
it is your door lock actuator that is causing the problem, the vehicle will not arm if it is unable to lock all the doors hence why you do not get the beep. If you manually lock the door then get out and hit your "lock" button it will beep once, but when you unlock your vehicle you will have to use your key to unlock the drivers door since your actuator is bad.
JKweezy (02-18-24)
Old 09-17-12, 02:27 PM
smajroh1
smajroh1's Avatar
Thanks for the help. Im looking for the actuator now, and I thought about getting one off a salvage IS.
Ken167
01-25-17 02:57 PM
mamasaurus
10-28-14 09:23 AM
avidreader
RX - 1st Gen (1999-2003)
02-28-13 03:38 AM
JDMHARRIER
06-20-06 01:20 PM
FILIPE
09-19-02 12:56 PM
Quick Reply: Stock alarm makes no arming beep?
