IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
2jzgte swap
Old 06-28-12, 06:58 AM
dsouthmia0
dsouthmia0's Avatar
I would say get this one its bad *** but I only see 6 bolts. Our flywheel is 8 bolts so call first
http://www.ebay.com/itm/CBHaus-Chrom...0106ed&vxp=mtr
I went with a 14lb flywheel because I didnt want a super light one but if I would have seen this one I would have grabbed it. & I dont know why the hell they are so cheap right now, they are normally at least $300 so I would jump on it
Old 06-28-12, 03:44 PM
wurm109
wurm109's Avatar
just did some research on that flywheel option. That is for the 7mgte motor and it is 6 bolt pattern. Found a couple forums about it and it would need some machining done to it to get it to fit and would overall weaken the flywheel. Atleast i know what to look for now found like 2 forums on people putting the w55 or w58 tranny onto the 2jzgte.
Old 06-28-12, 05:20 PM
llllllllll
llllllllll's Avatar
Contact my buddy Dan
He has a performance shop
And he built his 2JZ-GTE IS300 from ground up.
https://www.facebook.com/FSMoto
It's a beast
Old 06-28-12, 06:36 PM
wurm109
wurm109's Avatar
sick lookin car. I sent him a message. Thanks for the info. Gettin ready to do this swap next week.
Old 07-09-12, 03:27 PM
Dan@FSM
Dan@FSM's Avatar
Here's how it currently looks after building the motor. FYI, this is still a VVTI GE motor, except I did a full VVTI delete, so now it appears to be a GTE head with the valve covers/coil cover but with the tell tale driver's side water neck of the GE heads. Of course it wouldn't be complete without our FSMoto FFIM and ProSeries fuel rail. Excuse the clutter of the bay, still gotta clean it up some. Any questions you guys can email me. Dan@fsmoto.net
Old 08-23-12, 05:28 PM
Bnneil
Bnneil's Avatar
Very nice car! That's exactly what I want to put together! Nice work!
Old 09-08-12, 06:47 PM
MyLittleIS
MyLittleIS's Avatar
AWWWWEEEEEEEEE--- I need a few bits of advice with my swap too if anyone can help... Dan------you seem like the guy to ask.....
Old 09-08-12, 10:12 PM
RusBoar
RusBoar's Avatar
looks great!! and for sure not only looks!)) got same plans, but probably will just rebuild original engine.
but first want to change a trany for manual. do anybody know where to get a complete trany swap for is300 in canada? i'm new here so haven't found any.
Old 09-09-12, 12:15 AM
2jzRWD4me
2jzRWD4me's Avatar
That swap looks great, so basically its a Built OEM 2JZGE turbo'ed with a greddy style intake manifold and VVTi delete? How much would you charge to do something like this? I'm assuming you put a Supra Trans in it?
Old 09-09-12, 07:11 AM
403IS300
403IS300's Avatar
Why on earth would you have a MAF on there Dan? Im thinking you converted to MAP (or at least I hope you did) but it looks like at some point you ran MAF? Was there any particular reason for this?
Old 09-17-12, 10:08 AM
Dan@FSM
Dan@FSM's Avatar
That is our FFIM manifold kit for the GE motors. The motor is essentially the stock motor built. Head has a HEADGAMES valve job on it which is more than just touching the seats, that service alone pics up 30cfm on the intake and 40 cfm on the exhaust! Contact Dave over there for that work, it's ****
The head is running HKS 272 cams. The intake cam has to be put in a lathe and cut down to make it fit into the #1 cam journal due to it's length. We then used a non-vvti/gte cam cap on the first journal. It's very VERY important to check for clearance since caps are married to it's heads from the factory and mixing them could result in failure due to each head being different with the align bore/hone of the cam journals. We spec'd mine out with that new cap and it gave us the proper oil clearance and was aligned well where it bolts down. Been running a few thousand miles now with no issues.
If you are interested in having any work done like this, or our intake kit you can email me. dan@fsmoto.net
Good eye 403! Yeah at one point the MAF was being used and I never got around to making a new intake pipe for the turbo, or cutting the flange off and filling the hole and smoothing it back out. My car is running an AEM EMS, so it is now MAP based.
Old 08-29-13, 08:31 PM
konaboi808
konaboi808's Avatar
Good luck with the build. Im doin the same thing. Just im in hawaii n it sucks shipping shet here. If anyone got any ideas or anything, hit me up. Tryn to pick it up asap
jerimiah87
Build Threads
110
07-31-22 02:04 PM
VIP161
Performance
01-28-19 06:14 PM
ride303
Performance & Maintenance
03-16-12 09:09 PM
syedfaem
12-20-11 10:17 PM
Quick Reply: 2jzgte swap
