IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Indecisive if I should take of my fender liners.
Old 04-25-12, 01:25 PM
2JZSteven
2JZSteven's Avatar
Default Indecisive if I should take of my fender liners.
I am thinking about going lower. But my liners are getting in the way. I'm scared that if I take it off something might get damage. Anyone have any feedback if I should or not. Thanks.
Old 04-25-12, 02:10 PM
mrbananas
mrbananas's Avatar
I was thinking of the same thing since I tried using heat gun to remold it and eff up...
Old 04-25-12, 02:12 PM
d7620
d7620's Avatar
i'm planning to take mine off too. keeps on rubbing when i make a full turrn. just ziptie / tape all the wires together
Old 04-25-12, 02:35 PM
rvalero
rvalero's Avatar
Try using a metal roller when you remold the liner.
Old 04-25-12, 02:58 PM
mrbananas
mrbananas's Avatar
hmmm sorry for the stupid question but where do you get that roller?
Old 04-25-12, 03:07 PM
rvalero
rvalero's Avatar
It's called a seam roller. I believe it was intended for use on wallpaper. Try Home Depot.
http://www.bestmaterials.com/detail.aspx?ID=17084
Old 04-25-12, 03:24 PM
SuthrnGent
SuthrnGent's Avatar
I have about and inch or so of mine cut and it's no problem
Old 04-26-12, 01:29 PM
thatPOLISH
thatPOLISH's Avatar
id do what you gotta do to keep them in its better than dirty door jams
Old 04-26-12, 01:33 PM
TobiasSing
TobiasSing's Avatar
I cut a few inches of mine out from the 9:00 to 3:00 position. You can remove them though, no problem. It'll just look weird.
Old 04-27-12, 12:36 AM
d7620
d7620's Avatar
how bout reshaping it ? saw it somewhere on the forum...
Old 05-08-12, 10:04 PM
2JZSteven
2JZSteven's Avatar
i think i might try remolding them. so heat gun and that roller thing will work rvalero?
Old 05-08-12, 10:50 PM
rvalero
rvalero's Avatar
and some patience. I would also use a bucket of ice water and a rag. Cooling off the surface will help the plastic harden faster and help keep it from trying to regain it's original shape. Take your time, and be careful around the paint. This should help you out: https://www.clublexus.com/forums/is-...ay-1-a-10.html
Old 05-12-12, 07:45 PM
Roninsan
Roninsan's Avatar
I would try my best to retain my liners. Readjust, trim, or heat to reshape them. Would you not be hearing rocks and other crap flying off your tires and hitting the inner wheel well while you are driving if you completely removed the inner liners?
Old 05-29-19, 02:02 AM
imjohnnyle
imjohnnyle's Avatar
damn, those little details! wonder when our sc's will meet
melski415
08-21-11 05:56 PM
Cleanshots
SC- 1st Gen (1992-2000)
08-13-11 08:52 AM
radicalrev
05-13-08 05:08 AM
King7Two
13
01-10-08 08:12 PM
RICHYRICH
Suspension and Brakes
02-27-07 09:33 AM
Quick Reply: Indecisive if I should take of my fender liners.
