IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Power Steering Fluid Level is low
Old 12-11-11, 04:15 PM
wintondb
wintondb's Avatar
Default Power Steering Fluid Level is low
The fluid in my power steering fluid reservoir shows it to be at the low level line. How much fluid do I add to bring it up to the high line? Also, this is Dexron ATF fluid, right? I have a 2001 IS300.
Old 12-11-11, 11:46 PM
lookalike
lookalike's Avatar
you add until it comes to the correct level... its quite simple... and i would use dedicated power steering fluid that can be purchased from any autoparts store.
Or.... just go get your fluids topped off "professionally" at any oil change location... normally they will do this as part of any oil change anyway
Old 12-12-11, 06:38 AM
Endika
Endika's Avatar
I would suggest checking for any powersteering leaks
babyduke
ES - 5th Gen (2007-2012)
08-24-18 12:33 AM
RuninRoach
12-04-14 05:13 PM
ToyotaLexus
RX - 1st Gen (1999-2003)
02-12-09 10:05 AM
Purplexed
Maintenance
05-26-01 06:16 AM
Quick Reply: Power Steering Fluid Level is low
