IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Smog test fail
Old 12-10-11, 01:19 PM
sfgiants84
sfgiants84's Avatar
Default Smog test fail
I recently bought a 2004 lexus is300. Went to get it SMOG checked and it failed. Turned out my radiator was busted. 500 later my temperature i go back and it failed again with the car over heating.
Took it back to the shop and dude said there was a air pocket in the coolant tank. He fixed the problem and I've been driving around the last week without the temp going past the half way mark.
Just took it back to get it smogged and it failed again. How come the temp goes up when it is getting tested but i speed around on the street and it's fine? Does it have something to do with being on a slant? please advise thank you.
Old 12-11-11, 11:00 AM
lookalike
lookalike's Avatar
is your radiator fan working correctly? While you are moving air is being forced into the radiator when you are moving forward but if the car is standing still for extended periods of time without the fan working it can overheat...
Old 12-11-11, 06:01 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
what is this i don't even......
post up a scan of the smog test results, they will usually highlight the areas that caused you to fail.
Old 12-11-11, 06:05 PM
GS4_Fiend
GS4_Fiend's Avatar
You mean he ABORTED the test. No such thing as fail for overheat. Your car is overheating at a stand still, which means radiator could be plugged, time for a new one or the fans are not working. Last culprit would be the ECT itself.
Old 12-12-11, 11:41 AM
IanH
IanH's Avatar
Check fans r coming on as suggested above
itzmedeezy
09-12-14 11:55 PM
alladien
12-16-13 08:16 PM
Blakeg1991
06-27-13 05:12 AM
JLeffler
04-18-13 08:00 AM
cnstarz
07-19-11 06:38 AM
Quick Reply: Smog test fail
