IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Still got brake vibration after replacing rotor
Old 12-10-11, 12:08 PM
Skggyy
Skggyy's Avatar
Default Still got brake vibration after replacing rotor
Hi, car is around 130k. Even after replacing front rotors. I did not change the brake pad. Because it is still has more than 80 percent left. It is oem pad. there is a vibration from the front end while braking. It is much better after I got tire replace also. but there is still a very noticeable vibration. I can feel it is from right front. It make noise too. At the beginning I only resurface the rotor. But it didn't work. So I replace new one. Problem is still not solve. I drive high speed not hear any noise front suspesion area, couldbthis relate to lower ball joint? Or hub. I did notice a little bit run out when I pu new rotors on. Anybody got the same problem? I order one set brand new pad. It is on the way. But I am not sure if this will help.
Old 12-10-11, 07:40 PM
dedott21
dedott21's Avatar
check your wheel balancing in the front!
Old 12-10-11, 08:40 PM
KA8
KA8's Avatar
new rotors with used pads? Not sure if that's a good idea. Factory wheels or aftermarket market?
Old 12-11-11, 12:50 AM
Skggyy
Skggyy's Avatar
Just got new tire, balance is perfect
Old 12-11-11, 12:51 AM
Skggyy
Skggyy's Avatar
It is factory wheel
Old 12-11-11, 01:00 AM
k7q
k7q's Avatar
should have changed pads too
Old 12-11-11, 02:39 AM
will02
will02's Avatar
change your brake pads too, i had the same problem... got rotors machined... still vibrated so i got new rotors + pads n problem is now gone
Old 12-12-11, 11:39 AM
baadhabit
baadhabit's Avatar
is the vibration only while driving or when braking?
do you feel the vibration in the foot pedal or in the seat?
Old 12-12-11, 11:43 AM
IanH
IanH's Avatar
Also ask that wheels are checked for run out
Old 12-13-11, 09:34 AM
sway162
sway162's Avatar
Sounds like the new pads will solve the problem. I had the same issue. Keep us posted.
Old 12-13-11, 02:36 PM
Skggyy
Skggyy's Avatar
only on braking. the vibration is from pedal and steering wheel. i never feel it was from the seat.
Old 12-13-11, 02:38 PM
Skggyy
Skggyy's Avatar
will try this tomorrow after i receive the new pads. kind worry about. i still don't think the pad will cause that much vibration. I really hope you guys are right.....
Old 12-14-11, 10:38 PM
Skggyy
Skggyy's Avatar
Change the new brake pad, new rotor, new tires. the car still get noticable vibration. it is from right front of the vehicle. it shake like hell. got no idea what happen with my car after spending so much money. have to bring it to the machanic tomorrow. so sad......
Old 12-14-11, 11:28 PM
will02
will02's Avatar
hmmm... it could possibly be the bearing...? ive heard that the IS bearings are known to wear out quite commonly...
Old 12-14-11, 11:33 PM
Skggyy
Skggyy's Avatar
i think about the bearing too. but worn bearing will usually make noise when driving. but my car runs quite.
Quick Reply: Still got brake vibration after replacing rotor
