*BIG ASS PROBLEM RIGHT NOW!!!* and i need your help!
*BIG *** PROBLEM RIGHT NOW!!!* and i need your help!
kay, i was driving home yesterday. on the road, everything was fine. got to the hwy and then, starting to shake a little.. i didnt like it. exiting off to the nearest exit, the car had a hard time stoping. i mean like, i was pressing on to the brake and it shake like its freaking out. finally got to a complete stop and the car shake continuesly. i know something isnt right.. so i went to nearest store with the biggest parking lot. i got there and just when i was gonna go to the lot, the TRAC OFF light flashed. i parked the car and the car stop shaking. but the TRAC OFF light continue flashing... i try to go on home, it started to shake up again. bad as hell too... i made it home safely but theres something wrong with my car...
my car is an 01 lexus is300 w/ 144000 miles on it...
what do you guys think of whats going on? any help will be helpful...
could be a sensor or your brakes need to be bled..check this link out and see if it works for u:
https://www.clublexus.com/forums/is-...-flashing.html
SO I WENT GO BYE ME AND OBD2 ENGINE OR CODE READER... I GOT 13 CODE..
P0300
Multiple Cylinder Misfire DetectedP0301
P0301
Cylinder 1 Misfire Detected
P0302
Cylinder 2 Misfire Detected
P0303
Cylinder 3 Misfire Detected
P0304
Cylinder 4 Misfire Detected
P0305
Cylinder 5 Misfire Detected
P0306
Cylinder 6 Misfire Detected
P0120
TP Sensor/Switch 'A' Circuit Malfunction
P0430
Catalyst Efficiency Below Normal (Bank 2)
P0440
EVAP Control System Malfunction
P0441
EVAP System Incorrect Purge Flow Detected
P0446
EVAP Vent Control Solenoid Circuit Malfunction
P1349
Variable Valve Timing System (Bank 1)
P0300
P0301
P0302
P0303
P0304
P0305
P0306
P0120
P0430
P0440
P0441
P0446
P1349
p1349 and po120 are where your problem is. Do not drive the car. I'm thinking you need to have your timing checked and most likely have a throttle body issue. You may be better off just getting a used one but see what a mechanic says. Or get on my.is and start a thread so Jason can give you more info
Reset the codes, and then wait for the CEL to come back again. Then, post the first code that comes up. Obviously all of the codes you have right now are not accurate, when one cel comes up it can lead to other readings to be false which ends up giving you multiple codes.
Don't forget too report back on what the problem is...I have an 01' and want to know just incase this happens to my girl. Good luck bud, hope its nothing major.
um fyi if you still need help i have an account to whats called identifix its a program my shop uses to diagnose issues like this I believe dsouthmia0 is right on the tb but it may or may not be your timing belt skipping lemme know if you havent gotten it fixed man i will look it up
