IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
*BIG ASS PROBLEM RIGHT NOW!!!* and i need your help!
Old 01-02-12, 08:19 AM
hit42
hit42's Avatar
Originally Posted by ais300c
um fyi if you still need help i have an account to whats called identifix its a program my shop uses to diagnose issues like this I believe dsouthmia0 is right on the tb but it may or may not be your timing belt skipping lemme know if you havent gotten it fixed man i will look it up
Actually I haven't yet. Saving up and after the winters is over. Maybe spring. It's in no good to drive. Especially the winter.... So what do you got for me then.. it'll be sweet to hear...
Old 01-02-12, 08:23 AM
hit42
hit42's Avatar
Originally Posted by sic_boy01
Don't forget too report back on what the problem is...I have an 01' and want to know just incase this happens to my girl. Good luck bud, hope its nothing major.
Yep well do.. thanks..
Old 03-13-12, 07:00 PM
hit42
hit42's Avatar
So I finally started up my car again with a new battery (battery 3 years, car start up since November). I tested the codes again and they were cleared. Started it up, tested it on the road, then it started choking and shaking again at a complete stop. BUT, I OBDII code reader again and now this one popped up. P1349: VVT malfunction. Now I read about it and only problem is, didn't quite understand the symptoms of it (didn't explain much about it). So would anyone know the symptoms?
Old 03-15-12, 04:08 PM
itsdr3w
itsdr3w's Avatar
Sounds like a problem i recently had on my 01. Car started to shake like crazy, basically just like yours. I brought it to my mechanic and i ended up having to change a vvti sensor. Not sure which one cause i forgot to ask but i definitely changed a sensor in the vvti
Old 03-15-12, 05:02 PM
2k2IS300
2k2IS300's Avatar
i am a toyota certified technician and there is no way to tell for sure but to me it sounds like a throttle body issue or possible ecm issue
Old 03-15-12, 05:07 PM
2k2IS300
2k2IS300's Avatar
when i say no way to tell for sure, i mean without actually having it in front of me to look at- just to clarify
Old 04-02-12, 07:27 PM
hit42
hit42's Avatar
i got my car back now. and it seem to be the whole timing belt & and water pump... and spark plugs... strange right? but now its run like new.. will test drive it more tomorrow... and respond back..
Old 04-12-12, 08:29 PM
l0cness
l0cness's Avatar
Let us knoow what happens, I have a 2001 IS300 too!
cyberflip9
GX - 1st Gen (2004-2009)
06-04-23 06:43 AM
RXGS
11-23-11 10:34 AM
Supremeg56
GS - 1st Gen (1993-1997)
12
08-08-11 10:06 PM
Supremeg56
Florida Lexus Club
07-31-11 10:27 PM
Orkin
06-25-01 03:06 PM
Quick Reply: *BIG ASS PROBLEM RIGHT NOW!!!* and i need your help!
