IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
brake caliper clearance
Old 09-18-11, 06:01 PM
049x83
049x83's Avatar
Default brake caliper clearance
Hey guys,
anyone know if IS350 4 pot calipers with the 333mm rotor fit under IS300 5 spoke wheels? They fit under GS 17 inch wheels, but i'd like to make sure they fit under the IS five spoke wheels (diameter wise), i know i will need a spacer to clear the caliper...
Thanks for the help!
Old 09-19-11, 07:24 PM
pmpdaddyt
pmpdaddyt's Avatar
i doubt it... i tried to put on ls400 brakes and my stockies didnt fit
Old 09-20-11, 05:00 PM
049x83
049x83's Avatar
well, ive seen several members do the MKIV brake conversion on their is300 using a 15mm spacer to clear the caliper with the stock 5 spokes. the supra has 323mm rotors, so i was wondering if a 333mm rotor with the 4 pot calipers will fit under the stock 5 spoke. or should i just use the mkiv supra 323mm rotor instead of the is350 333mm.. this is for my cressida brake conversion btw..
Old 09-23-11, 01:31 PM
lakestreet
lakestreet's Avatar
yes need a deeper offset
cliffud
Suspension and Brakes
02-15-07 10:21 AM
Captain Bone
21
09-17-04 01:44 AM
kyle3481
12-04-03 12:40 AM
Manaray
33
11-08-02 06:20 PM
Quick Reply: brake caliper clearance
