I need advice on Camber kit plz help
I jus installed the BC racein coil overs on my 04 IS300 now i need to get a camber kit to get my camber rite i jus got my alignment done yesterday but im still way off on my camber. i looked up megan raceing camber kit and its (Negative Only) Front Upper $339.30 and for the Rear Toe Arms RH/LH $153.90 are these good or wat other ones are out there that can help me out?
SPC also make camber kits. TH Motorsports were doign a group buy.
Figs also makes a bunch of suspension stuff
http://www.figsengineering.com/suspension.htm
How low is your car?
Fig makes some great suspension products. In back, you will probably need both camber and toe arms. I have both myself. Once you get camber in spec, your toe will be way off, and you will need adjustable links to get it back in spec. After a certain point, the OEM toe links will be too short to compensate. Since he actually had an IS300, he'll probably be able to give you better tech support than Megan.
You should definitely work on getting your toe back in spec before camber if you want to save your tires. I'm not sure how far along the project is, but Fig is also working on front upper suspension arms to add more camber adjustment/correction.
megans front upper arms are only to give you negative camber, by dropping your car that automatically gives you a negative camber. so you might want to go with the spc front camber kit and megan in the rear
so i hurried and made the purchase of the megan camber kit front and rear. i lowered the car almost 2" in the front and the back is about 1.8" ill post pics when i take them i jus havent had time. did i do wrong buyin the front camber for my car? well it fix the camber in the front?
quick question can some 1 walk me through puttin on the camber kit or should i jus take it some where? i think me and my boy can do it i jus need a breif walk me through
