IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Inspection problems . Need new light for rear lip spoiler
Old 04-22-11, 05:58 AM
LexiSoSexi
LexiSoSexi's Avatar
Originally Posted by dedott21
why don't you buy and attach some red l.e.d. strips to it!try autozone or ijdmtoy.com! they shouldn't cost that much! or check out an ebay store call just lexus is300 parts! they have some reasonable parts!!! BTW?what kind of rims and what size are you running??i like them!
Thanks there Tenzos 19s F 225/35 R 245/35 conti ext contacts dws
Attached Thumbnails Inspection problems . Need new light for rear lip spoiler-0421111417-02-1-.jpg
Old 04-22-11, 07:56 AM
llllllllll
llllllllll's Avatar
Originally Posted by LexiSoSexi
so if the autoleveling goes bad you replace the whole headlight assembly or that located somewhere else. ECU? I will get in touch with some junkyards and ebay. thanks
No!!
The levelers have nothing to do with the headlight housings.
The brain/controller for the levelers is a common piece that goes bad.
Can find it used for about $100.
But before you even adjust that there is this little thing by the rear suspension you should adjust it and hopefully it will solve your problem.
You should adjust the little level sensor by the rear suspension (if your car is height modified). First adjust that, then check the controllers.
If the lheadlight evelers are bad, most likely only one leveler will break and the other will still function, it would be easy to notice because one headlight moves but the other doesnt.
But if both levelers are being wacky then it's not the actual levelers, the problem is somewhere with the controller or the leveler sensor needs adjustment by the rear suspension.
surfsunset
SC- 1st Gen (1992-2000)
19
04-28-18 04:32 PM
DMWill
03-05-10 02:04 PM
pjfernan
07-12-07 09:34 AM
lexluv0277
12-30-04 09:25 AM
nudderGS400
09-12-02 10:54 AM
Quick Reply: Inspection problems . Need new light for rear lip spoiler
