IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
2 flat tires in the same month!
Old 03-19-11, 12:22 AM
2JZSteven
2JZSteven's Avatar
Default 2 flat tires in the same month!
So I got the first flat tire and thought ehh no biggie. But 20 mins ago I got another flat tire on the spare tire I put on couple weeks ago... Idk whats wrong!
And I was a dumbass and tried to go home on a flat but ended up pulling to the side and the inside of my tires are destroyed from driving too long on a flat....
Old 03-19-11, 02:51 AM
llllllllll
llllllllll's Avatar
Is it the same wheel position?
Maybe there is something protruding that is cutting the tires.
But since you rode home on the flat, whatever was there, was probably destroyed or moved out of the way when you were driving on the flat
Driving on a flat is dangerous, especially when the tire gets super destroyed in the process.
That shiiiiiit gets messy when you drive too far, you're lucky you didn't destroy your fender & rim....
Are you on stock suspension or lowered?
If lowered maybe you have a wicked camber issue, when's the last time you got an alignment?
Old 03-20-11, 09:13 PM
hit42
hit42's Avatar
suck. i had my first flat tire on my rear passenger side. and there was bubbles everywhere on the other of the tire. which cause the flatten tire. but i dont know what cause that.
Old 03-20-11, 11:26 PM
Meowmr2
Meowmr2's Avatar
One thing people neglect to do is to check the tire pressure in there Spare.
Old 03-20-11, 11:39 PM
fathorsejr
fathorsejr's Avatar
maybe its just a bad patch of tires?my girl had the same problem with her bf goodrich tires,we changed out to falkens and haven't had a problem since.
Old 03-21-11, 09:49 AM
Justin727
Justin727's Avatar
This is true!
Not too long ago I checked mine and of course it had little to no pressure.. Hooked up to our nitro machine and converted it. The next week I got myself a flat and was thanking myself for checking it. Normally I do check over these things but @ the time I just recently purchased the car and luckily caught that when I did. I usually carry a cig lighter compressor just in case.
Aeromotive
Wheels, Tires & Brakes Forum
04-13-15 03:05 PM
ChrISF
02-11-11 09:50 PM
handoverfi
07-18-09 04:45 PM
sc400123
Suspension and Brakes
08-28-08 08:46 PM
newyorksc
04-13-05 10:43 AM
Quick Reply: 2 flat tires in the same month!
