will 215/40/17 will be fine on stock is rims?
well the stock size is 215 45 17 and i saw anice set of 215 40 size tires in good shape for good price, should i go for it?
will it cause any problems or will it be any significant change
So will the acceleration suffer, what about mpgs, explain this poor slob the physics of tires in relations 2 car
usually illl just but a diff set of rims than buying tires for stock wheels but those 5 spokes are so tastefull and look yummii on is id yet to see a car like that from factory
There is nothing to worry about between 30 series 40 and 55, as far as mpg ride stuff like that, the lex drives so nice u won't really notice a difference between sizes. Get whatever ones u like 40 will be just fine
If you are dropped 2 inches, you probably won't want to run 215/55/17. The OD will be 1.7 inches taller than stock, and you will probably rub on the inner fender...especially if you don't remold the fender liner. You definitely don't want to run this size if you have spacers for flush fitment. Changing the tire's OD will also throw off your speedometer a little.
There shouldn't be any significant problems with the 215/40/17. The speedometer will be a little off, and your wheels will be slightly more prone to pot hole damage, but I don't see there being anything to be too concerned about.
http://www.1010tires.com/TireSizeCal...?action=submit
thanks so much ^
i have a chance 2 buy set of tires on rims for $100, the rims are for german cars (5x112) made by zender(good *****) and tires i am not sure yet but are name brand ones
