IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
abs light is on and trac light is blinking on cluster
Old 12-08-10, 12:27 PM
RX7 RAGE
RX7 RAGE's Avatar
Default abs light is on and trac light is blinking on cluster
What does this mean? It's happened a couple times now and I've removed the battery cable to reset it. It's a 2002 IS300.
Old 12-08-10, 08:31 PM
03LexIS300
03LexIS300's Avatar
It means there is some kind of fault with your ABS system. Could be a wheel speed sensor, ABS pump, or anything ABS related. Go to a local garage and have the codes read on a scan tool. I'm not 100% sure, but I believe Auto Zone can only read your check engine light, and that is free. But that does not help you in this case. You can always stop at your local Auto Zone and see if they can read the ABS codes or not.
Old 12-08-10, 08:38 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
I don't know why folks don't just pull the code. The SC guys have to guess at everything that goes wrong, but the IS guys have ODBII, USE IT!!!! LOL..... it's great.
Anyone with a snap-on scanner can read detailed computer info. Even an old MT2500.
Old 12-08-10, 09:08 PM
03LexIS300
03LexIS300's Avatar
haha thats a great point O.L.T., and yes the snap-on scanners can do just about any make and model. I know there are a few exclusions like volvo and suzuki, maybe one or two more, but you can always go under the global OBII and read some codes. I have a snap-on modis scanner at work and it is one of the best scanners I have ever used.
Old 12-09-10, 07:42 AM
RX7 RAGE
RX7 RAGE's Avatar
I didn't think it was an OBDII issue since the check engine light wasn't on. Since I have a scanner, I'll go ahead and pull the codes.
Oh btw, I still need to ship you my sc cluster. lol I still need to get around pulling that damn thing out.
SebCypher
10-18-17 08:44 PM
aymaddemir
02-25-17 11:24 AM
Toshihiro
Suspension and Brakes
02-04-12 05:20 AM
jimbo22s
Maintenance
12-04-09 03:38 PM
Quick Reply: abs light is on and trac light is blinking on cluster
