IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
smoke from exhaust on cold starts. ugh!
Old 11-15-10, 03:41 PM
flavs23
flavs23's Avatar
Default smoke from exhaust on cold starts. ugh!
so i got into my car this morning and noticed a puff of smoke from my exhaust when i started it. so its time for new valve stem seals, which totally sucks cus i just did my timing belt, water pump, crank, and cam seals earlier this year! and now i have to take it all off again to do my valve stem seals..
Old 11-16-10, 07:40 AM
llllllllll
llllllllll's Avatar
Smoke from exhaust on cold startup is normal especially when it's cold outside........
Unless it's like an unusual crazy amount of smoke I see no problem..?
Old 11-16-10, 09:42 AM
wagomaniac
wagomaniac's Avatar
^what he said
Old 11-16-10, 10:02 PM
03LexIS300
03LexIS300's Avatar
smoke is very normal on a cold start up. valve stem seals???? did you mean valve seals in your head? valve stems are in your wheels and what you use to put air in your tires haha
Old 11-18-10, 02:28 PM
flavs23
flavs23's Avatar
haha u got me on that one! ya i mean valve seals! my bad
Old 11-18-10, 02:34 PM
flavs23
flavs23's Avatar
true,but not when i live in phx and weather is still in the mid 80's. ive done seals on other cars like camrys with the 2AZ-FE motor and also other toyotas with the 3MZ-FE.
Old 11-18-10, 05:28 PM
llllllllll
llllllllll's Avatar
Oh... yeah I been there, it's hot a balzz
Does the smoke smell like oil? (headgasket)?
Does the smoke have a really strong smell (maybe its running rich)?
If the smoke has a strong smell then I would look into it soon.
Old 11-18-10, 05:46 PM
flavs23
flavs23's Avatar
no smell, but this tends to happen with toyotas. thanks tho! im just pissed cus now i have to take my t-belt off and new cam seals when i just did it all myself back in jan of this year.
Old 11-18-10, 10:18 PM
03LexIS300
03LexIS300's Avatar
im not sure if this works on the 2jz but i know on some cars you can remove the valve cover and run compressed air in the cylinders and replace the valve seals with the cylinder head still on the block, so that way you won't have to take the head off or replace the head gasket.
Old 11-19-10, 04:07 PM
TOPSECRTIS
TOPSECRTIS's Avatar
My 2009 4Runner does the same thing occasionally, I wouldn't sweat it.
Old 11-21-10, 04:07 PM
flavs23
flavs23's Avatar
that is true and that is what i plan on doing. now i just have to wait for a day off to work on my car.
Old 11-21-10, 06:41 PM
03LexIS300
03LexIS300's Avatar
Is your car using any oil?
ZiPPyRCF
RC F (2015-present)
09-02-17 04:09 PM
twizted
Performance & Maintenance
05-19-08 01:07 PM
blk99rx
Maintenance
06-25-04 09:52 AM
Quick Reply: smoke from exhaust on cold starts. ugh!
