IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
1jzgte swap
Old 09-27-10, 03:50 PM
zludespide
zludespide's Avatar
Default 1jzgte swap
I was wonder if anyone knows about this when i get back to the states im getting a IS300 and a friend of mine suggested this swap so i was wanting to know more about it
Old 09-27-10, 04:21 PM
wagomaniac
wagomaniac's Avatar
search! But I wouldnt downgrade from a 2jz vvti to a 1jzgte. If anything just go na-t or
2jzgte
Old 09-27-10, 09:29 PM
slidingIS
slidingIS's Avatar
yeah downgrade is not your best option. Kingluis6 is right stay 2jz
Old 09-27-10, 09:48 PM
03LexIS300
03LexIS300's Avatar
agreed, stay 2jz
Old 09-28-10, 06:48 AM
baadhabit
baadhabit's Avatar
i wouldnt consider a 1J a downgrade. its a good motor and can produce some good HP numbers.
but to the OP, you have lots of options when modding the IS. NAT, 1J and 2J swaps even V8 swaps. all depends on what your interst is and your budget
Old 09-28-10, 08:44 AM
03LexIS300
03LexIS300's Avatar
that is very true, also swapping a TT 1jzgte would have more power than a stock 2jzge, I guess the reason they are calling it a downgrade is going from a 3.0 liter to a 2.5 liter.
Old 09-28-10, 10:27 AM
baadhabit
baadhabit's Avatar
heres one example of a 1J in an IS
http://my.is/forums/f114/dexlexs-1jz...-build-417574/
http://my.is/forums/f90/engine-bay-p...needed-419142/
Originally Posted by dexlex
here is the dyno sheet:
Old 09-28-10, 12:37 PM
zludespide
zludespide's Avatar
Hey thanks for the in put
Old 09-28-10, 01:18 PM
wagomaniac
wagomaniac's Avatar
Yeah but that swap is legit because its a 1jzgte with vvti and single turbo off a chaser, not just a regular 1jzgte
Old 09-29-10, 07:18 AM
baadhabit
baadhabit's Avatar
but but.....
Old 09-29-10, 07:21 AM
baadhabit
baadhabit's Avatar
a few more examples.
Originally Posted by Frydryce
finally here are some engine bay pics! i'll take exterior shots after the brake install and a good carwash =)
here you can see the madness of the Skyline IAC system. its retarded - has a separate regular IAC and a coldstart solenoid however both feed into the same hole. the solenoid must be plumbed into the chargepipe and not open air because they are known to leak boost.... i hate nissan.
c's shifter with TRD ****. i also got a shifter extension to raise it up about 2" from stock. shifts at this height are nice and easy and my hand doesn't have to move as far down for shifts. "shortened" shifters FTL!
i still love the look of the weld cover every time i look at it =)
Old 09-29-10, 10:30 AM
wagomaniac
wagomaniac's Avatar
but but.....
??? And your point is???
Old 09-29-10, 05:17 PM
zludespide
zludespide's Avatar
This is the way im looking at it. If i can do a 1jz gte or vvti cheaper then 6000 then thats the way i want to go from the looks of it i can still get 450hp out of either engine
Old 09-29-10, 10:38 PM
wagomaniac
wagomaniac's Avatar
yeah you can get good power out of any of these engines, 2jzge na-t, 1jzgte,1jzgte vvti, 2jzgte (with or without vvti)
If it was me I would just go with the best, 2jzgte vvti (even though some argue that you can get more power out of the non vvti). You can get those engines for around 2k~3k. After that you would still have 2k~3k for labor and parts
But thats just me
Old 09-29-10, 10:43 PM
slidingIS
slidingIS's Avatar
^ agreed.....
Quick Reply: 1jzgte swap
