IS300 Wheels
IS300 Wheels
Hi everyone! I have a 2002 IS300 w/stock wheels and I'm thinking to get a following set:
Sport edition model A7.
18” x 8’
Off Set :+ 35 mm
Back Space : 5.94
Bolt Pattern : 5.114
Sumitomo Ultra High Performance All Seasons
245-40-18
Will it fit w/o problems?
18” x 8’
Off Set :+ 35 mm
Back Space : 5.94
245-40-18
YEA THAT WILL WORK I THINK 245-40-18 IS TO MUCH I DO 235/40/18 BEND THE IN SIDE OF THE FENDERS THEN IT WILL NOT RUB I HAVE 20s THE TRICK IS THE TIRE I HAVE 225/30/20 THE RIM IS 20X9 5.114.3 O AND IT'S BROP 2.5 SO I KNOW YOU'LL BE GOOD CHECK IT
The outside diameter of a 245/40/18 is 1.1" taller than OEM. That size can work, but be prepared to do a lot of front fender work. I doubt it would look good either. With those offsets, you should look at 225/40/18 or 215/40/18. Depending on how low your car is, you may need to roll the fronts. The rear should be sunk enough to go as is.
98supra6sp
SC- 1st Gen (1992-2000)
11-18-09 10:54 AM
