IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
ECT Light
Old 08-03-10, 07:34 PM
infra917
infra917's Avatar
Default ECT Light (Solved)
My ECT light is now showing up when the button is pressed. Snow is working though. Is there a fuse for this display?
Old 08-03-10, 10:01 PM
03LexIS300
03LexIS300's Avatar
there are fuses for the displays on the cluster, but if it were a fuse it would affect more displays than just that one. it sounds like the ect bulb is blown out and it is easily replaceable. take the 2 screws out of the cluster cover, they are above your steering wheel and once those are out that cover pops right off, unhook the dimmer switch control, take the 3 screws that hold your cluster in out. and unhook the 2 harnesses going to your cluster and pull the cluster out. there are 2 bulb sockets to the right on the backside of your cluster, one is the snow button(the bottom bulb socket), the other is ECT Power(the top bulb socket) take a pair of pliers and twist the top bulb socket out and see if it is blown, if so replace it, the bulb pulls right out of the black socket. the bulb number is 2721 and its a sylvania bulb. about $5 or $6 at auto zone for a pack of 2.
Old 08-04-10, 04:04 AM
UNOHOO
UNOHOO's Avatar
this DIY should help you see how to get to it
http://www.isfanatics.com/forums/showthread.php?t=3352
Old 08-04-10, 11:46 PM
slidingIS
slidingIS's Avatar
well explained lexIS300 5 stars haha
Old 08-05-10, 08:39 AM
infra917
infra917's Avatar
Followed your instructions and bingo! Bulb was dead!
thanks alot!
Old 08-05-10, 09:15 PM
03LexIS300
03LexIS300's Avatar
thanks man
Old 08-05-10, 09:18 PM
03LexIS300
03LexIS300's Avatar
thanks alot!
anytime my friend, glad i could help
6.0PSD
RX - 1st Gen (1999-2003)
12-12-16 06:16 PM
Garymkrieg
184
08-25-16 10:21 PM
Alexbenz
05-15-15 01:50 PM
bobinyelm
15
02-22-12 05:53 PM
mr29rose
06-09-07 06:57 AM
Quick Reply: ECT Light
