IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
head light leveling sensor on?!?!?wtf
Old 01-06-10, 08:31 PM
parker06
parker06's Avatar
Default head light leveling sensor on?!?!?wtf
any one know how to check or fix it?????the light use to come on when i went threw a car wash or it rained out,but i cant find where its causing the problem.when the light did coome on the light shined up like the high beems were on,but now there normal and when it goes off they shine up?.?.where is the sensor?sorry its a 01 is300
Old 10-03-10, 03:37 PM
dirkdiggle
dirkdiggle's Avatar
I am having the smae issue with the leveling warning light on.
where are the little sensors that need to be aligned located exactly?
Old 10-03-10, 04:42 PM
llllllllll
llllllllll's Avatar
It is a common problem with lexus's after a while..
I actually have the same issue I just ignore it but it's kinda annoying.
Headlight leveling has 2 items
#1 - The actual headlight levelers that make the lights move up and down.
As long as both of your headlights move up and down then your levelers are fine.
#2 - The leveler computer aka module/controller. The leveler computer is most commonly the thing that gets screwed up. You can unplug the leveler computer and your headlights won't be annoying and move up and down anymore when you are driving, but the warning light will be on the dash. Or you can get a new leveler computer, can find them for like $100 used. I think the only way to fix it is to buy a new leveler, maybe you can try to take it apart and figure it out if you are good with electronics, but I have never heard of anyone taking one apart and fixing it, if there is a DIY leveler computer fix for that I'd LOOOOOOOOOVE to see it!!
Old 10-03-10, 05:38 PM
dirkdiggle
dirkdiggle's Avatar
Are there sensors located on the sway bar or something also?
Old 10-03-10, 08:21 PM
03LexIS300
03LexIS300's Avatar
the leveling sensors are on your drivers side front and rear wheels, they are very easy to rebuild. they commonly go bad due to moisture getting in them and the corrode. I had actually just rebuilt mine on my 04 IS before my friend wrecked it. take the sensors off and take them apart and get some good electrical contact cleaner and clean the contact points in side the sensors and replace the 3 brass springs inside each sensor. they are very easy to fix, you can use springs from an ink pen. then I would put some sealer on the rubber seal to make sure it is sealed up good and put it back together, and re-install them. make sure the rear sensor is adjusted right and the light will instantly go off.
Old 10-04-10, 08:08 AM
llllllllll
llllllllll's Avatar
Oh yeah I forgot about that!
I had to unscrew & raise the rear sensor when my car was lowered because the light always came on, there is a post on here or my.is about it.
Old 10-04-10, 08:31 AM
sway162
sway162's Avatar
That is the sensor.....dog bone shape (driver side front and rear). Make sure it is perfectly vertical. As seen in the pic (not mine), it's not straight therefore will cause your sensor light to come on.
Old 10-04-10, 08:40 AM
03LexIS300
03LexIS300's Avatar
Also, to add the actual sensor is that little yellow box to the right of what he has circled.
toomanytoy
03-30-15 06:45 PM
AnimalB
07-25-13 08:10 AM
aggatek
01-21-12 06:36 PM
Matthias
09-07-09 09:57 AM
shooter300
11-02-06 05:58 PM
Quick Reply: head light leveling sensor on?!?!?wtf
