IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
IS300 problem with check engine light
Old 01-05-10, 11:32 PM
Rominu7
Rominu7's Avatar
Default IS300 problem with check engine light
How do you shut off the check engine light on an IS300?
Old 01-06-10, 08:36 AM
DonCorleone
DonCorleone's Avatar
Fix whatever problem that's triggering it.
Old 01-06-10, 09:23 AM
UNOHOO
UNOHOO's Avatar
hah hah hah hah hah hah
well yea fix the issue but lets say you did and it didnt turn off you need to reset it, you have a few options, unplug the battery for a few min/use a scanner tool/or if there is no problem and you just dont want to see the light you can take the gauge pod out and remove the bulb for it
i had to do this cause i put my headers in and it causes a CEL and i have yet to get around to getting an o2 simulator
Old 01-06-10, 09:25 AM
ATX300
ATX300's Avatar
If you already fixed the problem, check your owner's manual to be exact, but I believe that you have to hold the odometer reset button while starting the car and it should count down from 5 dashes to 1 and then it should be reset.
Old 01-06-10, 11:46 AM
Mv350
Mv350's Avatar
thats for the oil reminder, its universal on all toyota/lexus
kchat99
05-23-19 06:26 AM
AAHawaii07
18
11-13-15 11:54 AM
eep4life
06-14-12 12:25 AM
Dtwillis5
01-20-11 08:43 PM
Ferrari-F1
07-25-02 09:50 PM
Quick Reply: IS300 problem with check engine light
