This Forum is Sponsored By:
Go Back   Club Lexus Forums > Lexus Model Forums > IS Models > IS - First Generation
Thread Tools Display Modes
Old 10-28-09, 05:52 PM   #1
jrubs1
Trader Score: (0)
Send a message via AIM to jrubs1
Default Problem after oil change
Hope someone can help me
model - 2003 is300
OK, so i decided to do my oil change the other day. I switched from synthetic to conventional oil and everything went fine. When i started the car and backed out of the drive way i noticed it was stuttering when you are stopped and hit the gas (almost as if its not catching the gears right away). Also if you give it some gas to move forward you hear the engine rev and about 5 seconds later it catches it and jolts as if you were trying to burn out. I checked the lines next to the oil filter and everything is in place. I also read that it could be that the MAF sensor is dirty, so i cleaned it with the MAF cleaner from auto zone and disconnected the battery to reset the ECU - however there was no change. Can someone please let me know what else it can be ??
jrubs1 is offline   Reply With Quote
Old 10-28-09, 07:02 PM   #2
VIPJOSH
2001 Lexus IS
Trader Score: (0)
idk what your problem is but i have always heard that it is bad to go back after your car has received synthetic
__________________
Do you not know that those who run in a race all run, but only one receives the prize? Run in such a way that you may win. - 1 Corinthians 9:24
VIPJOSH is offline   Reply With Quote
Old 10-29-09, 05:24 AM   #3
UNOHOO
2003 Lexus IS
My Garage
Trader Score: (2)
UNOHOO's Avatar
Send a message via AIM to UNOHOO
x 2 on vipjoshs comment, you shouldnt go from syth back to dino
lets start with the basics though, what filter did you use? what oil did you use and what weight? what did you notice about the oil you were draining out?
as far as your "burnout" issue, that sounds more drivetrain than engine, but keep listing symptoms and testing and we will help you as much as we can
__________________
99 RX300 - 230k miles - Wifes Car - Running Strong
03 IS300 - 88k miles - My Car - Amazing!
parts i have for sale: http://www.isfanatics.com/forums/sho...098#post531098
UNOHOO is offline   Reply With Quote
Old 10-29-09, 05:34 AM   #4
tromly
Trader Score: (0)
+1 on the drivetrain issue, that can't be related to your oil change. Good Luck
tromly is offline   Reply With Quote
Old 10-29-09, 09:21 AM   #5
O. L. T.
Trader Score: (5)
O. L. T.'s Avatar
The car is pissed.
I would be too if you took me from steak to chicken.
__________________
O. L. T. is offline   Reply With Quote
Old 10-29-09, 12:50 PM   #6
BDSL
Trader Score: (0)
Switching back and forth between synthetic and conventional oil will NOT damage your engine.
Maybe your oil cap or oil dip stick is not fully secured. Or did you drain and fill the transmission fluid instead?
BDSL is offline   Reply With Quote
Old 10-29-09, 04:35 PM   #7
UNOHOO
2003 Lexus IS
My Garage
Trader Score: (2)
UNOHOO's Avatar
weeeelllllllll.............i dont remember exactly what it was saying but i read an article on bobistheoilguy.com one time about switching oil based on what was on sale, like i said i dont remember the actual reason they were saying it was bad but that it was, switching once and staying with that one no issue but going valvoline, castrol, pennzoil, etc etc etc was not good, maybe it was something to do with the additives each manufacturer puts into their oil and how those interact with each other, like i said i cant remember
Thats what i was thinkin too! thats why i asked about what did he notice about the oil itself when draining it
__________________
Old 10-29-09, 07:16 PM   #8
BDSL
Trader Score: (0)
Valvoline, Castrol (Made in USA), Pennzoil, Mobil 1, Quaker State, etc are only group III synthetic oil.
Whereas Redline, Royal Purple, Amsoil and a few others are true group IV synthic oil.
Once again, there is no harm switching back and forth between synthetic and conventional oil.
Old 11-03-09, 02:49 PM   #9
purebliss
Trader Score: (0)
Did you accidently drain the tranny fluid?
purebliss is offline   Reply With Quote
Old 11-03-09, 03:50 PM   #10
Marsin
Trader Score: (0)
yeah..... thats an unusual problem u have.....check out your trany oil qty!
Marsin is offline   Reply With Quote
Old 11-03-09, 03:52 PM   #11
Marsin
Trader Score: (0)
and was it yourself that changed the oil or a shop of some sort
Tags
is300. 2003, oil, problem
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Go
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
