IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Rear endlink bolt for sway bar install
Old 06-28-09, 12:43 PM
-JDOG-
-JDOG-'s Avatar
Default Rear endlink bolt for sway bar install
Hey guys,
I just recently purchased a set of new L-Tuned sways.
I've run into one problem, I'm not sure if there is something I'm doing wrong or what.
Here is a picture to show ya'll.
The circle surrounding the rear endlink bolt (14mm) is a pretty tough little bolt. After finaly being able to get some muscle into it. It budges. But it just keeps turning. It will not come off.
I've searched the few DIY's there are and they say all you need for that part is a 14mm socket.
Any ideas?
Old 06-28-09, 12:53 PM
iKenn
Just call me "Sprinkes"
iKenn's Avatar
uh.... I say, hammer it out.
Old 06-28-09, 12:54 PM
-JDOG-
-JDOG-'s Avatar
What the hell Ken?
I should of known not to expect anything realistic out of your post.
Old 06-28-09, 12:59 PM
eric_r_ho
eric_r_ho's Avatar
You have to counter-hold it with an allen key wrench, not sure which size it is but it's around 5mm. Don't round it out or you're in for a bit of hurtin'.
Old 06-28-09, 01:24 PM
-JDOG-
-JDOG-'s Avatar
What do you mean by "don't round it out?"
Old 06-28-09, 03:49 PM
LexusGSXR
LexusGSXR's Avatar
stripping it, is wat he means....
Old 06-28-09, 09:32 PM
Mmarinich
Mmarinich's Avatar
If the allen key does not hold, you can use a pair of needle nose vise grips to hold the part from spinning. If worse comes to worse, you can always resort to a cut-off tool if you have access to a compressor.
Old 06-29-09, 11:21 AM
eric_r_ho
eric_r_ho's Avatar
As in don't use the wrong size of allen key and strip the hexagonal shape in there making it "round" and not being able to hold the stud as you turn the nut. make sure the allen key fits nice and snug before you give it a turn.
dminah21
09-01-18 08:04 AM
98GSOwner
Suspension and Brakes
03-20-18 01:49 PM
Champstar
06-19-15 07:18 AM
engin_ear
13
11-14-12 03:47 PM
GILLEXUS
17
10-03-06 09:52 AM
Quick Reply: Rear endlink bolt for sway bar install
