IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
popping noise when break
Old 07-02-08, 11:22 PM
I<3myIS300
I<3myIS300's Avatar
Exclamation popping noise when break
i got a nice popping noise on my is300 when i come to a stop after backing up but on top of that i have a hard time sometimes getting it into reverse i have to run it into 1st gear than back into reverse for it to work any suggestiong on this?
Old 07-03-08, 08:30 AM
juniorsdad
juniorsdad's Avatar
popping noise from the breaks is normal.
as for having a hard time getting in reverse (assuming you're 5 spd), it could be the synchros are going...?
Old 07-03-08, 02:03 PM
Faymester
Faymester's Avatar
why post the same q 2x in the same secion?
Old 07-03-08, 04:20 PM
I<3myIS300
I<3myIS300's Avatar
ya thats wat i was thinkin too i just got the trani fluid changed and so far so good i dont have problems shifting into other gears and the car has 46k miles on it so idk its hard for me to think that they would be going out already
Old 07-06-08, 02:17 PM
KPC
KPC's Avatar
Default same
Heyy im having the same problems...when i back up and brake, the brakes make a popping noise (almost like the brake pads are sliding back and forth) and when i move foward and brake the pop as well like they are sliding back...also about the reverse thin...i have he same problem onnly sometimes its hard to get it into reverse...i usually just put it into neutral and release the clutch...then push clutch back and then itll go right into reverse...weird..my car has 45k on it..i dont think itcould be the syncros also?...
Chilton88
Hybrid Technology
09-07-19 09:42 AM
mattbruner
Suspension and Brakes
05-31-12 08:01 PM
I<3myIS300
07-03-08 10:46 AM
JohnnySpag
08-30-06 07:40 PM
Lisa_LX
06-19-04 01:15 PM
Quick Reply: popping noise when break
