IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
question for 2001 is 300
Old 06-25-08, 09:27 PM
hdhaliwal
hdhaliwal's Avatar
Default question for 2001 is 300
i bought a 2001 is 300 salvaged and a bunch of stuff was unpluged i got the whole car back together almost but i cant figure out were one conector goes its a small 2 wire comector run along side the 2 conectors to the fans the wires i believe are like a aqua or greenish blue and white with black lines i think id apricate alot i dotn wanna start the car and read the codes because the air bag is not in
Old 06-26-08, 02:55 AM
ace263
ace263's Avatar
Take a picture of what your describing. It will be helpful...then you might get an answer. Ill take a look under the hood today. 2JZ-GE ?
Old 06-27-08, 12:40 PM
jaydee818
jaydee818's Avatar
You're... umm.... missing some commas and periods. After the 1st line I couldn't follow what you were trying to say.
Old 07-01-08, 06:34 PM
hdhaliwal
hdhaliwal's Avatar
the 2 wires run up with the fan plugs then splits off some were, the wire colors are blue and white with a black stripe its a small little conector, i would take a picture but my cameras broken. the split is drectly under the high side a/c port just behind the driver side head light. thanx guys really need your help
Rolexus600
SC- 1st Gen (1992-2000)
24
01-16-03 09:56 AM
myblack2001 IS
12-03-01 09:07 PM
1niceride
04-20-01 10:04 AM
Quick Reply: question for 2001 is 300
