IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Foggy Headlights?
Old 06-16-08, 06:30 AM
ace263
ace263's Avatar
Default Foggy Headlights?
I am beginning to notice that my headlights are beginning to looked fogged. I have even went as far to polish the outside with turtle wax and it didnt make a difference. Any ideas??
Old 06-16-08, 10:15 AM
lexdymndz
lexdymndz's Avatar
get some meguiars plastix or any polish designed specifically for plastics. i've also heard that toothpaste works, depending on how bad it is. (worth a shot, you already have toothpaste (i hope))
if that dont work, you might need something a little more abrasive. wetsanding, do NOT attempt if you don't know what you're doing.
Old 06-16-08, 02:21 PM
IS3_FTW
IS3_FTW's Avatar
Here is a tuturial on wetsanding headlights. But remember that the tuturial is for glass headlights, not plastic. Just read what others have said, and take there advice.
http://my.is/forums/f90/tutorial-wet...erison-277763/
Good Luck
Old 06-16-08, 11:31 PM
ace263
ace263's Avatar
Great I appreciate the input. Ill take pics of what it looks like before and after Thanks for the info fellas!
Old 06-17-08, 09:20 AM
ISDreams
ISDreams's Avatar
bro when u say foggy u mean the outside or inside if its the inside silicone them it happened 2 mine and it blow out my ballest good luck either way
Old 06-18-08, 09:14 PM
ace263
ace263's Avatar
To be honest I am unsure. I've tried putting the turtle wax on the outside which doesnt look like it accomplished much. I havent had the time to try anything else at this point. I know exactially what your talking about though. I had a small crack on one of my headlights then shortly after a few rainy days the ballast went out. I went out and bought a used ballast and housing... But now im noticing this on both lights. So I'm not sure if this is something to do with the extremely dry heat or what. Once I get a minute I'll post a reply. Thanks again!
Old 06-19-08, 05:07 PM
IS3_FTW
IS3_FTW's Avatar
^^^If thats the case, then doing that DIY wouldnt help. Its only for the outside part of the lense.
Good Luck, hopefully you get it worked out.
TEXAS83
North Texas Lexus Club
06-10-10 06:13 PM
Sheehan1p
07-30-09 02:04 PM
rpx13
05-30-05 07:50 AM
ShowGSLuVv
08-24-02 11:14 AM
007
04-07-02 06:18 AM
Quick Reply: Foggy Headlights?
