IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
doors lock with speed
Old 08-12-07, 10:29 PM
tlis300
tlis300's Avatar
Default doors lock with speed
hello all frist time for me.
I have a question I am the proud new owner of a 2003 IS300 well new to me at least. My question is: can I program my car to have the door locks lock when I reach a certain speed (i have a 5speed) and unlock after the engine is shut down or only the dealer can do this?
thanks.
Old 08-13-07, 11:26 AM
mjnoles1
mjnoles1's Avatar
Sorry to tell you but only the 2004 and 2005 IS300 can do that.
Old 08-13-07, 11:46 AM
btorok
btorok's Avatar
Yeah they lock as soon as you put it into gear, and it's my understanding that only '04 and '05's do it too.
Old 08-13-07, 07:35 PM
2OO4IS300
2OO4IS300's Avatar
How do you program them to do that? I have an 04'.
Old 08-13-07, 07:54 PM
btorok
btorok's Avatar
Yours doesnt? Mine always has. Anyone know if that sort of programming is in the service manual?
Old 08-13-07, 08:54 PM
BlueIS05
BlueIS05's Avatar
Here you go...the instructions below can also be found in the manual.
Setting the functions
1. Close all the doors.
2. Turn the ignition switch to the “ON” position.
3. Within 10 seconds after the ignition switch is turned to the "ON" position
To set function (a) (locks linked with shift position - auto trans only)
Push and hold the front of the power door lock switch for 5 seconds with the selector lever in the “P” position.
To set function (b) (unlocking linked with shift position - auto trans only)
Push and hold the rear of the power door lock switch for 5 seconds with the selector lever in the “P” position.
To set function (c) (locking linked with vehicle speed)
Push and hold the front of the power door lock switch for 5 seconds with the selector lever in any position except “P”.
To set function (d) (unlocking linked with opening driver's door.)
Push and hold the rear of the power door lock switch for 5 seconds with the selector lever in any position except “P”.
All the doors automatically lock and unlock when you release the power door lock switch. This indicates that the function is set. If all the doors do not lock and unlock, the time the switch was held may have been too short or too long. Perform theprocedure over again starting from step 1.
If you want to cancel a function, repeat the procedure. Each time you perform the procedure, the function is set or canceled.
Old 08-17-07, 12:22 PM
tlis300
tlis300's Avatar
thanks all I guess I can purchase aftermarket electronics that can do this for me, once again thanks
Old 08-20-07, 06:48 PM
BernieIS
BernieIS's Avatar
A simple remote start from DEI will do that for you
seulloui
12-02-18 09:49 AM
GoHuskers
NX - 1st Gen (2015-2021)
03-03-17 08:50 PM
rottwailer
10-31-13 09:09 PM
rfong
09-16-06 10:34 AM
puppasmurf
04-20-06 10:06 AM
Quick Reply: doors lock with speed
